Upgrading 20A to 40A Breakers for 240V Plasma Cutter—Will This Prevent Tripping?
279 6
  • #1 21683579
    STEVENS BRIONNI
  • #2 21683580
    Giovanni Di Maria
  • Check cable sizing and breaker type first
    #3 21683581
    Alan Gallagher
  • #4 21683582
    ariana456 cafe
  • Promotional wiring ad with no technical content
    #5 21683583
    Naresh Joshi
  • Explaining 240-volt circuits and 40A breaker wiring
    #6 21683584
    Arthur11
  • #7 21683585
    Dinesh198
A 240-volt circuit was created using two 20-amp circuit breakers on a main panel to power a plasma cutter rated at 20 amps, but the breakers tripped under load. The question was whether upgrading each breaker from 20 amps to 40 amps would prevent tripping. Responses clarified that simply increasing breaker ratings is not sufficient and may cause safety hazards. The circuit wiring must be appropriately sized—typically #8 gauge wire for a 40-amp breaker—and the breaker type must match the load characteristics, especially for plasma cutters or welders which may require specialized breakers. Using a double-pole breaker is necessary for 240V circuits, connecting to both 120V buses. Proper coordination with upstream breakers and ensuring the electrical service capacity is adequate are critical. Consulting a qualified electrician is recommended to ensure compliance with electrical codes and safe operation.
