Beginner Audio Amplifier Circuit Design: Basic vs Class D Schematics and Differences
468 9
How do I build a simple beginner audio amplifier with BJT transistors, and how does a class AB circuit differ from a class D design?
For a fast beginner build, use a simple class AB audio power amplifier with BJT transistors rather than class D, because class D adds a lot of extra circuitry [#21683631] The needed output power and frequency response should be given as design requirements; if they are not, a rough assumption is 1–5 W and 50–10000 Hz [#21683629] Most circuits for that range would use an integrated circuit rather than discrete transistors, but a simple class AB schematic is available and easy to make quickly [#21683629][#21683631] Class D amplifiers are very efficient and stay cool, but they are more complex than class AB [#21683625][#21683631]
  • #1 21683624
    pola hshh
  • #2 21683625
    Giovanni Di Maria
  • #3 21683626
    David Ashton
  • #4 21683627
    pola hshh
  • #5 21683628
    pola hshh
  • Need output power and frequency specs first
    #6 21683629
    David Ashton
  • #7 21683630
    pola hshh
  • #8 21683631
    David Ashton
  • #9 21683632
    pola hshh
  • Basic TIP35C class A amplifier parts list
    #10 21683633
    Jay Solanki
The discussion addresses the design differences between basic Class AB and Class D audio amplifier circuits for a beginner in electrical engineering. Class AB amplifiers use transistor pairs operating in partial conduction to reduce distortion and overheating, typically implemented with BJTs or integrated circuits. Class D amplifiers operate with high efficiency (up to 98%) by processing digital signals and require more complex circuitry. Key design parameters such as output power and frequency response are essential and usually provided; if not, typical assumptions include 1-5 watts output and 50-10,000 Hz frequency range. For rapid prototyping without integrated circuits, simple Class AB amplifier schematics using BJTs are recommended, with resources available on Electronics Tutorials. An example of a basic Class A amplifier circuit using a TIP35C power transistor with minimal components and a 12V supply was also shared, highlighting the trade-offs in performance and complexity between amplifier classes.
