MATLAB scripts or models for grid frequency measurement in demand side management?
258 12
How can I prototype a grid-frequency measuring device for a demand-side management system in MATLAB/Simulink and then implement it on an Arduino?
You can prototype the frequency measurement as a simple edge-timing circuit: convert the AC input to a square wave with a comparator, then measure the time between rising or falling edges with a timer, interrupt, or counter and convert period to frequency [#21683809] On an Arduino Uno, the 16 MHz clock limits timing resolution, so accuracy and speed will be constrained; a higher-clock CPU or a more capable board would improve frequency measurement, but relative measurements may still be good enough if you document the inaccuracy [#21683811][#21683816] For the measurement side, use electrical isolation such as a transformer to step the voltage down, and for control use relays or another isolated drive circuit for the loads/breakers [#21683818] If you are simulating the grid reaction, load changes can cause frequency changes on a generator-driven system, but the effect is usually small and momentary unless the load is a significant part of the total [#21683813]
  • #1 21683808
    Josh McNelis
  • Comparator-based period measurement for grid frequency
    #2 21683809
    Elizabeth Simon
  • #3 21683810
    Josh McNelis
  • Arduino Uno timing limits may reduce frequency accuracy
    #4 21683811
    Elizabeth Simon
  • #5 21683812
    PeterTraneus Anderson
  • Load changes cause momentary generator frequency shifts
    #6 21683813
    Elizabeth Simon
  • Arduino feasibility for frequency-based load control
    #7 21683814
    Josh McNelis
  • #8 21683815
    Josh McNelis
  • Recommend higher-clock ARM boards for frequency monitoring
    #9 21683816
    Elizabeth Simon
  • Asking for circuit tips for Arduino Simulink prototype
    #10 21683817
    Josh McNelis
  • Use isolation transformers and relays for safety
    #11 21683818
    Elizabeth Simon
  • #13 21683820
    leah melda
The discussion focuses on developing a prototype frequency measuring device for domestic demand side management to maintain grid stability by monitoring frequency deviations and controlling loads accordingly. The measurement approach involves converting the analog voltage input into a square wave using a comparator, then measuring the time interval between edges to calculate frequency. An Arduino Uno is proposed for frequency measurement and load control, but its 16 MHz clock and interrupt latency limit measurement resolution and accuracy. Clock drift and timing calibration are also concerns for precise frequency measurement. Alternatives with higher processing power and clock speeds, such as Raspberry Pi, Beaglebone Black, or ARM-based Teensy boards compatible with the Arduino IDE, are suggested for improved resolution and data handling. The circuit design should include electrical isolation between high voltage and low voltage control circuits, typically achieved using transformers for measurement and electromechanical relays or drive circuits for load switching. Simulation in MATLAB/Simulink is recommended before hardware implementation. The system aims to emulate grid frequency response by switching three-phase loads via circuit breakers to stabilize frequency within tolerance limits.
TL;DR: Use a comparator to square the mains sample, then time edge-to-edge with your MCU; Arduino Uno’s 16 MHz clock limits resolution, and “Any load change on a generator driven power system will cause a frequency change.” [Elektroda, Anonymous, post #21683813]
Why it matters:** This FAQ helps students and hobbyists build and simulate a safe, Arduino-based grid‑frequency monitor for demand‑side control.
How do I measure grid frequency with an Arduino?
Condition the mains sample safely, feed it to a comparator to create a clean square wave, and use the MCU timer to measure time between rising (or falling) edges. Convert period to frequency or count edges in a fixed time window. This approach is simple, fast, and works across wide frequency ranges if your timing resolution is adequate. [Elektroda, Anonymous, post #21683809]
What accuracy and speed can I expect from an Arduino Uno?
The 16 MHz clock sets base resolution (one tick ≈ 62.5 ns), but real accuracy depends on interrupt latency and the Uno’s clock drift. For relative changes, it works well; for absolute frequency, add calibration or a better timebase. “You’re going to need an accurate time source and/or calibration.” [Elektroda, Anonymous, post #21683811]
Do I need galvanic isolation for measurement and switching?
Yes. Isolate the measurement path with a small transformer that also steps voltage down. Isolate control paths with electromechanical relays or appropriately rated drivers for breaker coils. Even if a breaker’s input is isolated, you may still need a driver stage to meet coil current or voltage. [Elektroda, Anonymous, post #21683818]
Can small domestic loads really change grid frequency?
On a large interconnected grid, single‑home load changes cause only slight, momentary frequency shifts. In a small, controlled lab system, deliberate load steps are visible and useful for experiments. “Any load change … will cause a frequency change,” but magnitude depends on the system’s size and inertia. [Elektroda, Anonymous, post #21683813]
Is Arduino enough, or should I use a faster board?
Arduino can work, but higher‑clock MCUs or SBCs improve timing resolution and processing. Teensy, Raspberry Pi, or Beaglebone provide more headroom; Linux SBCs also simplify raw data capture for later analysis. If you’re constrained to Arduino, optimize timers and interrupts carefully. [Elektroda, Anonymous, post #21683816]
How should I model this in MATLAB/Simulink before building?
Create blocks for a voltage source, frequency measurement, controllable three‑phase loads, and breaker logic. Define frequency thresholds to trigger shedding or restoration. Validate timing and control logic in simulation, then port thresholds and logic to your Arduino for hardware testing. [Elektroda, Anonymous, post #21683817]
What is a comparator and why use it here?
A comparator outputs a digital high or low depending on the input’s instantaneous voltage. With an AC sample, it turns a noisy sine into a clean square wave with sharp edges. That clean edge makes timer‑based period or edge‑count measurement stable and repeatable. [Elektroda, Anonymous, post #21683809]
How do I switch three‑phase loads safely from a microcontroller?
Keep the MCU at low voltage. Use isolated relay interfaces or properly rated drivers to actuate contactors or breakers. Verify the breakers’ control inputs; some are isolated low‑voltage coils, others need specific drive currents and protection. Maintain isolation barriers between mains and logic. [Elektroda, Anonymous, post #21683818]
Quick how‑to: measuring frequency on Arduino Uno (3 steps)
  1. Square the conditioned AC sample with a comparator and feed a digital pin.
  2. Use an external interrupt to capture edges and read a hardware timer.
  3. Compute frequency from period or count edges within a fixed gate time. [Elektroda, Anonymous, post #21683809]
How do I choose thresholds to shed or restore loads?
Define upper and lower frequency limits around nominal. When frequency drops below the lower limit, shed selected loads; when it rises above the upper limit, restore them. Your prototype can emulate grid logic by reacting “when the system frequency rises or falls past the given tolerances.” [Elektroda, Anonymous, post #21683814]
What’s an effective control loop for demand‑side response on a bench setup?
Measure frequency continuously, apply hysteresis on thresholds to avoid chatter, and switch loads in priority order. Log frequency and switching events to tune thresholds. Start with coarse steps, then refine timing and load sizes for stability and minimal overshoot. [Elektroda, Anonymous, post #21683810]
How can I log data for my dissertation?
Use a faster MCU or a Linux SBC to timestamp frequency, voltage, and switch states. Store raw data to files for replay and analysis. This makes it easier to validate controller behavior and produce publication‑quality plots. [Elektroda, Anonymous, post #21683816]
What is the Arduino Uno in this context?
It’s a 16 MHz microcontroller board suitable for timing edges and controlling relays. Its limited clock speed and non‑disciplined oscillator affect frequency resolution and absolute accuracy, so consider calibration or a higher‑quality clock if needed. [Elektroda, Anonymous, post #21683811]
What edge cases or failures should I plan for?
Interrupt storms or long ISRs can delay edge capture and distort period measurements. Oscillator drift skews absolute frequency. Mitigate by minimizing ISR work and calibrating timebase. Document these sources of error and their impact in your report. [Elektroda, Anonymous, post #21683811]
