Best Temperature Sensors for Compacted Soil, Arduino vs Raspberry Pi Data Logging
261 7
  • Recommendation for robust low-cost soil temperature sensors and logger
    #1 21683943
    Cyrena Ridgeway
  • Thermocouples recommended for high-temperature logging
    #2 21683944
    Richard Gabric
  • Twenty-channel logging favors scanner and analogue processor
    #3 21683945
    Richard Gabric
  • Clarifies 5–30°C range and 20-sensor logging needs
    #4 21683946
    Cyrena Ridgeway
  • Thermistor and thermocouple sensor recommendations
    #5 21683947
    Richard Gabric
  • #6 21683948
    rytham12 john
  • Arduino Mega with 16 thermistor inputs
    #7 21683949
    Steve Roberts
  • Diode string as low-cost temperature sensor
    #8 21683950
    James Van Damme
A geotechnical engineer seeks robust, accurate temperature sensors for embedding in a compacted soil cylinder (1 ft long, 6 in diameter) to optimize geothermal heat pump systems. The temperature range is 5-30°C, with 20 sensors measuring every minute for 12-24 hours. Budget constraints limit sensors to $15-20 each. Thermocouples (types J and K) are robust and suitable for high temperatures but may exceed budget when including signal processing electronics. Thermistors are the cheapest option, requiring calibration and linearization, and can be made more robust by embedding in small metal blocks. Semiconductor IC sensors like the LM34 offer simple voltage outputs but need power and may be less robust. The user has access to an Agilent 34972A LXI Data Acquisition/Data Logger with a 20-channel multiplexer module, which supports thermocouples and thermistors. For data logging, Arduino Mega 2560 with 16 analog inputs is recommended for simplicity and cost-effectiveness, though it supports fewer channels than needed. Raspberry Pi offers Python programming and USB connectivity but requires additional analog input modules and driver support, making it more complex. Diode-based sensors (e.g., 1N4148) are a low-cost alternative with voltage output proportional to temperature but require custom circuitry. Overall, thermistors or thermocouples integrated with the Agilent system or Arduino Mega are practical solutions balancing cost, robustness, and accuracy for soil temperature monitoring.
