I thought maybe there was some current going through the voltmeter but then to me it doesn't make sense that there would be a difference in voltage across it.The basis of this Geiger tube is that the wire at the base of the first transistor is not touching the coffee can and so the only current going through is the current coming from the ions inside the coffee can created by ionizing radiation.I also don't know whether to call it a Darlington pair transistor as there is no supply voltage connected to the collectors of the transistors.Any and all help would be appreciated concerning the operation of these two transistors, I have built this circuit using my limited materials and I get a reading of around 1-5 volts on my voltmeter but I presume that's all mostly noise.
Colton Jones
Colton Jones
