I'm looking for a simple circuit that monitors incoming AC power and turns a red led or green led based on whether the AC power is present or not. I have a ball feeder for a pitching machine that runs on 120v power. When it's turned on, it slowly rotates a small knob that slowly feeds balls into the machine. The goal is to have a red led light up when the unit is switched on and have a green light turn on when the unit is switched off (but it still is plugged into 120v AC outlet). I want to let the batter know when the feeder is on (red led) or off (green led) so they can safely move around without getting hit by the ball. Very simple concept. Trying to do it the easiest way possible. The feeder unit is only 5" x 4" x 4" so I would like everything to fit into the existing box to keep it simple. Thanks in advance. Dan
Dan Mccarthy
Dan Mccarthy
