Bi-Color 3-Pin LED Fuse Status Circuit for 5V, 12V, 36V DC up to 40mA
396 23
How can I wire a 3-pin bi-colour LED to show green when a DC fuse is OK and red when it is blown on 5 V, 12 V, and 36 V circuits?
Use a relay in each supply line and drive the bi-colour LED as a common-cathode indicator: choose a relay whose coil voltage matches the line voltage, and use a change-over contact to switch the LED from red to green [#21664814] With power applied and the fuse open, only the red LED lights; with a good fuse, the relay energizes and the contacts switch to green [#21664814] Use these series resistors for the LED side: 150 Ω for 5 V, 200 Ω (220 Ω is OK) for 12 V, and 1.5 kΩ 1 W for 36 V [#21664814]
  • #1 21664793
    Raymond Smith
  • Clarifying supply voltage and fuse placement
    #2 21664794
    Mark Harrington
  • Series LED fuse indicator may leave residual load voltage
    #3 21664795
    Cody Tappan
  • Fuse rectifier supplies before and after the bridge
    #4 21664796
    Mark Harrington
  • #5 21664797
    Cody Tappan
  • Snubber capacitors reduce rectifier ringing and EMI
    #6 21664798
    Mark Harrington
  • #7 21664799
    Mark Harrington
  • #8 21664800
    Peter Owens
  • #9 21664801
    Mark Harrington
  • Op-amp window comparator schematic for fuse status
    #10 21664802
    Mark Harrington
  • Clarifying fuse indicators for CNC PSU rails
    #11 21664803
    Raymond Smith
  • Clarifies CNC PSU rails and LED-only fuse indicators
    #12 21664804
    Raymond Smith
  • Two fuses needed before and after transformer bridge
    #13 21664805
    Floy Viola
  • #14 21664806
    Raymond Smith
  • Simple fuse status indicator using four LEDs
    #15 21664807
    Frank Bushnell
  • #16 21664808
    Raymond Smith
  • Solid-state fuse with relay and reset switch
    #17 21664809
    Mark Harrington
  • Concern about R1 losses and fuse type choice
    #18 21664810
    Peter Owens
  • #19 21664811
    Raymond Smith
  • #20 21664812
    Frank Bushnell
  • #21 21664813
    Frank Bushnell
  • Relay-based bi-color fuse indicator with line-specific resistors
    #22 21664814
    Frank Bushnell
  • #23 21664815
    Raymond Smith
  • Recommend local suppliers and beginner electronics resources
    #24 21664816
    Frank Bushnell
The discussion centers on designing a bi-color 3-pin LED fuse status indicator circuit for DC voltages of 5V, 12V, and 36V with currents up to 40mA, intended for CNC machine control circuits including power supplies, breakout boards, and stepper motor drivers. The user seeks a simple visual indication using a single bi-color LED (red for blown fuse, green for good fuse). Various contributors suggest methods including placing LEDs in series with the fuse and across it, noting voltage drops and residual currents when fuses blow. The importance of fuse placement relative to rectifiers is discussed, emphasizing fusing before the bridge rectifier to prevent damage to transformers and smoothing capacitors. Relay-based solutions are proposed for clearer indication, using relays with coil voltages matching the supply lines to switch the bi-color LED states. Resistor values for different voltages are recommended to limit LED current. The conversation also touches on fuse types (fast blow vs slow blow) and their appropriate applications. Practical advice includes sourcing small PCB-mount relays and using solderless breadboards for prototyping. Simulation tools like Proteus are mentioned for circuit testing. Overall, the solutions balance simplicity for beginners with considerations for reliability and circuit protection.
TL;DR: Need a simple fuse-status indicator? Use a relay-per-rail with a 3‑pin bi‑color LED; e.g., 1k5 Ω/1 W on 36 V. “When power is applied, if the fuse is open circuit, only the red LED is lit.” [Elektroda, Frank Bushnell, post #21664814]
Why it matters: This gives clear green=OK/red=blown feedback on 5 V, 12 V, and 36 V rails without leakage issues.
How do I wire a 3‑pin bi‑color LED to show fuse good vs blown on DC?
Simplest: put the green LED in series with the fuse, cathode toward the load. Put the red LED and a resistor across the fuse, cathode toward the load. Green means current is flowing. Red lights when the fuse opens. Expect a small forward‑drop in normal operation and some residual power at the load when blown. Highly resistive loads can impair indication. [Elektroda, Cody Tappan, post #21664795]
Will the LED‑across‑fuse trick leak current to my load when the fuse blows?
Yes. The red LED path supplies a small current to the load side after the fuse opens. This produces a non‑zero voltage that can confuse high‑impedance loads. "It may or may not work" if your load is very resistive. Consider an isolated method if that is unacceptable. [Elektroda, Cody Tappan, post #21664795]
How can I avoid voltage drop and leakage while still using a bi‑color LED?
Use a small relay per rail. Drive the relay coil from the rail before the fuse. Wire the relay’s changeover contacts to select red (fuse open) or green (fuse OK) on a common‑cathode bi‑color LED. This isolates the indicator from the load path and eliminates leakage into the load. [Elektroda, Frank Bushnell, post #21664814]
What resistor values should I use with the bi‑color LED at 5 V, 12 V, and 36 V?
For a common‑cathode LED: use 150 Ω on 5 V, 220 Ω on 12 V, and 1k5 (1 W) on 36 V. These values come from a proven relay‑indicator scheme and keep LED current modest. Adjust slightly if your LED is unusually bright or dim. [Elektroda, Frank Bushnell, post #21664814]
Fast‑blow or slow‑blow fuse—what’s right for stepper drivers and logic supplies?
Use fast‑blow (F) for delicate logic like breakout boards. Use slow‑blow (T) for stepper drivers and motors because they draw higher start‑up current. This balances protection with nuisance‑trip avoidance during inrush. [Elektroda, Frank Bushnell, post #21664807]
Where should I place fuses around a PSU or rectifier?
Place one fuse at the AC input and another before the bridge rectifier on the transformer secondary. This reduces collateral damage if rectifier diodes fail and helps protect the transformer and smoothing caps. "A fuse is not fail safe." [Elektroda, Mark Harrington, post #21664796]
Is a fuse truly fail‑safe?
No. Fuses can fail to clear properly, leaving other parts to absorb fault energy. That is why designers protect both primary and secondary sides in rectified supplies. As Mark notes, “a fuse is not fail safe.” [Elektroda, Mark Harrington, post #21664796]
Can I simulate the indicator circuit before building it?
Yes. Mark shared a Proteus design you can run in Labcenter’s simulator. Simulation helps verify LED polarity, resistor sizing, and relay logic before soldering. It also lets you test at 5 V, 12 V, and 36 V rails safely. [Elektroda, Mark Harrington, post #21664801]
Is there a solid‑state alternative to fuses and relays?
Yes. You can build a CPU‑controlled electronic fuse using an op‑amp window comparator, opto‑isolation, and a microcontroller driving a relay or MOSFET. It offers fast cutoff and reset features, but adds complexity and design time. [Elektroda, Mark Harrington, post #21664802]
How do I size indicator current within my rail budget?
Keep indicator draw small relative to each branch’s limit. The original brief targets up to 40 mA per DC branch. Using 2–5 mA per LED leaves ample margin for the load and keeps heat low. [Elektroda, Raymond Smith, post #21664793]
Will large dropper resistors waste power continuously?
Yes, simple resistor drops dissipate heat while the rail is on. Peter raised this loss concern. Frank’s view: favor simplicity for beginners, but a PWM or smarter driver can improve efficiency if desired. [Elektroda, Frank Bushnell, post #21664813]
What’s a safe, visual method for beginners to implement?
Adopt the relay‑per‑rail LED indicator. It is robust, easy to debug, and uses clear red/green states. Sample values: 5 V→150 Ω, 12 V→220 Ω, 36 V→1k5/1 W on a common‑cathode LED. This avoids confusing partial‑power conditions. [Elektroda, Frank Bushnell, post #21664814]
How do I build the relay‑indicator in three steps?
  1. Feed each relay coil from its rail before the fuse.
  2. Put the relay’s common on LED cathode; NO→green, NC→red via resistors.
  3. Connect LED anode to ground (common cathode). Verify green with a good fuse, red when open. [Elektroda, Frank Bushnell, post #21664814]
Any tips for sourcing relays and prototyping this?
Frank suggests small PCB relays; they are cheap and easy to mount on stripboard. Buy from reputable suppliers or eBay if time permits. A solderless breadboard helps you prototype and confirm LED polarity and coil wiring before final assembly. [Elektroda, Frank Bushnell, post #21664816]
What if my system monitors AC rather than DC rails?
Use opto‑couplers or inductive pickups to sense AC safely, then feed a comparator or microcontroller. Drive a relay or MOSFET to isolate and signal faults. This approach also supports a master relay to disconnect mains on error. [Elektroda, Mark Harrington, post #21664809]
What mains and PSU context did the original build use?
Ray’s CNC controller used 240 VAC at 10 A into a PSU providing one 5 V rail for logic and three 36 V rails for stepper drivers. He wanted per‑fuse indicators with simple red/green status. [Elektroda, Raymond Smith, post #21664803]
