What is the difference between Boost/Buck Controllers and Inverters/Transformers?
435 13
How do boost/buck controllers differ from inverters and transformers, and do they increase power or only change voltage?
Boost and buck controllers are active DC-to-DC circuits: a boost converter gives a higher DC output than its DC input, while a buck converter gives a lower DC output, and in both cases the output power is approximately the input power multiplied by efficiency, not a power increase [#21684727] An inverter is an active device that converts DC to AC; a 12V DC to 220V AC inverter does not create new power, it simply draws much more current from the 12V source to supply the required output power, for example about 10A for 100W ideally and around 12A with losses [#21684732] A transformer is passive and changes one AC voltage to another using two coils on the same core; it does not amplify, and the power on both sides is ideally the same apart from losses [#21684727] Boost/buck converters typically use inductors rather than transformers, while inverters often include a transformer plus electronics that switch DC into AC first [#21684727][#21684732] A useful way to think of them is that boost and buck converters are like step-up and step-down transformers for DC, and an inverter is like a transformer between DC and AC [#21684729] None of these devices amplifies power; an amplifier is a different kind of circuit that uses an external power source to make a larger signal [#21684727]
  • #1 21684722
    David Fong
  • #2 21684723
    Maurizio Di Paolo Emilio
  • #3 21684724
    David Fong
  • #4 21684725
    David Fong
  • #5 21684726
    David Fong
  • Definitions of boost, buck, inverter, and transformer
    #6 21684727
    David Ashton
  • #7 21684728
    David Fong
  • #8 21684729
    John David Heinzmann
  • #9 21684730
    David Fong
  • Clarifying whether inverters increase power
    #10 21684731
    David Fong
  • Inverter power draw and transformer distinction
    #11 21684732
    David Ashton
  • Inverter power drawn from 12 VDC source
    #12 21684733
    David Fong
  • Power balance and inverter input-voltage explanation
    #13 21684734
    David Ashton
  • Buck boost transformers are not DC converters
    #14 21684735
    jessewalter375
Boost and Buck controllers are active electronic DC-DC converters that respectively increase or decrease DC voltage while maintaining power output approximately equal to power input multiplied by efficiency (up to about 95%). They typically use inductors and transistors/ICs but not transformers. Inverters convert DC input to AC output, often employing similar switching circuits combined with transformers to step up voltage. Transformers are passive devices consisting of two coils on a shared magnetic core that convert AC voltages by changing coil turns ratio without electronic components, maintaining power balance minus losses. Power output in all these devices does not exceed power input, considering efficiency losses. Inverters, such as 12V DC to 220V AC types, increase voltage but draw proportionally higher current from the DC source, thus not creating additional power. Advanced inverters produce sine wave AC outputs using sophisticated electronics, while simpler designs may generate square waves. Buck-boost transformers, often used in high-power switching applications and forward converter circuits, facilitate DC voltage conversion and inverter functions through pulse width modulation and inductive filtering. Solar grid-tied inverters incorporate complex electronics to synchronize output phase and voltage with the grid. Overall, these devices transform voltage and current characteristics but do not amplify total power beyond input limits.
TL;DR: DC‑DC buck/boost converters can hit about 95% efficiency; “None of these devices amplify.” They trade voltage for current, so power out ≈ power in minus losses. This FAQ explains how bucks, boosts, inverters, and transformers differ, with clear examples. [Elektroda, Anonymous, post #21684727]
Why it matters: If you’re sizing power gear or troubleshooting sagging voltage, knowing that converters don’t create power prevents burnt parts and dead batteries.
What’s the difference between a buck, a boost, an inverter, and a transformer?
A boost raises DC voltage; a buck lowers DC voltage. Both are active switch-mode stages. An inverter converts DC to AC, often using similar switch-mode blocks plus a transformer. A transformer passively shifts AC voltage using two windings on a common core. None of them create power. [Elektroda, Anonymous, post #21684727]
Do any of these devices amplify power?
No. They convert voltage and current while conserving power minus losses. “None of these devices amplify.” Amplifiers increase signal power by drawing extra energy from a supply, which is different from conversion. [Elektroda, Anonymous, post #21684727]
How can a 12 V inverter run a 220 V appliance without increasing power?
It raises voltage but draws more current from the 12 V source. Example: 100 W at 220 V is about 0.55 A, but at 12 V that same 100 W needs around 10 A, or about 12 A including losses. The inverter doesn’t create power; it trades current for voltage. [Elektroda, Anonymous, post #21684732]
What efficiency should I expect from buck/boost converters?
Expect high efficiency, with good designs reaching about 95%. Actual efficiency depends on components, switching frequency, magnetics, and load. Plan thermal and input current for real, not ideal, efficiency. [Elektroda, Anonymous, post #21684727]
How efficient are transformers?
Quality transformers are highly efficient. The thread cites “well above 90%” for good units. Core material, frequency, and loading affect losses. Ferrite cores suit higher frequencies; laminated iron cores suit mains frequencies. [Elektroda, Anonymous, post #21684732]
Do buck/boost controllers use transformers?
Typical buck and boost regulators use inductors, not transformers. Some topologies add transformers for isolation or large ratios, but the common non‑isolated buck/boost stages are inductor‑based. [Elektroda, Anonymous, post #21684727]
What does RMS mean for AC power calculations?
Use RMS (root mean square) voltage and current when calculating AC power. The basic relation is Power = Volts × Amps, using RMS values. Good meters report RMS, which makes comparisons to DC straightforward. [Elektroda, Anonymous, post #21684734]
What’s inside an inverter?
A typical design includes switching electronics to generate AC from DC and a transformer to step voltage as needed. Simple units output a square wave. Pure sine wave models add more sophisticated control to shape the output. [Elektroda, Anonymous, post #21684732]
Quick calc: How many amps from 12 V for a 100 W load?
About 10 A at ideal efficiency, and around 12 A allowing for losses. As voltage increases at the output, input current rises to conserve power. This is why cabling and fusing on the 12 V side must handle high current. [Elektroda, Anonymous, post #21684732]
Can I power an inverter from any DC source?
Use the specified input voltage range. Car inverters target about 12 V. Solar inverters may accept a wider DC range and must synchronize phase and voltage when grid‑tied. Without proper phase and voltage offset, they won’t feed the grid. [Elektroda, Anonymous, post #21684734]
Is a buck‑boost “transformer” the same as a buck‑boost converter?
Terminology varies. Some switch‑mode literature calls push‑pull or forward‑converter transformer stages “buck‑boost” applications. They’re magnetic stages within DC‑DC or inverter systems, not the simple non‑isolated buck‑boost regulator. Context matters. [Elektroda, Anonymous, post #21684735]
What is a forward converter in plain terms?
It’s a switched‑mode power supply topology that uses a transformer and pulse‑width modulation to produce a regulated DC output. An output inductor reduces ripple. Designers may refer to related stages with terms like inverter, DC converter, or buck. [Elektroda, Anonymous, post #21684735]
How do I calculate inverter input current from a known AC load?
  1. Compute load power: P_load = V_out × I_out (use RMS if AC).
  2. Estimate input power: P_in ≈ P_load ÷ efficiency.
  3. Compute input current: I_in ≈ P_in ÷ V_in. Example: 100 W ÷ 0.85 ≈ 118 W; at 12 V, I_in ≈ 9.8 A. [Elektroda, Anonymous, post #21684734]
Why do people think converters “amplify”?
Voltage may rise dramatically, which looks like amplification. But current falls so power stays similar minus losses. True amplifiers use an external supply to increase signal power. Converters only trade voltage and current. [Elektroda, Anonymous, post #21684727]
What happens if my inverter isn’t a pure sine wave?
Functionally, simpler designs can output a square wave, while pure sine models use more complex electronics. Choice affects compatibility and performance, but both still obey power conservation. “It’s easy enough to make a square wave inverter.” [Elektroda, Anonymous, post #21684732]
