I connected a hobby electric motor to an arduino. One lead was connected to a pin labeled 3.3 volt and the other lead was connected to a ground pin. I did not connect the electric motor to a digital input/output pin. I did not connect the electric motor to an analog pin. The electric motor stopped working. I tried connecting the motor to a 4 battery. The motor would not start. The motor was rated 3 volt to 5 volt. Why is the motor not starting?
david lopez
david lopez
