Powerful Stepper Motor Options for Arduino CNC Shield+A4988 RepRap: 17HS13-0404S-PG27 Specs
skosiu 5655 6
  • Clarifying A4988-compatible motor torque for 3 kg Z-axis load
    #1 16299336
    skosiu
    Rate: 8
    What is the most powerful stepper motor that can be connected to the set: Arduino CNC Shield + A4988 RepRap?
    The problem is that the engine on the Z axis will operate with a weight of about 3kg.
    I wonder if this would be the answer (planetary gear version):
    Manufacturer Part Number - 17HS13-0404S-PG27
    Motor Type - Bipolar Stepper
    Step Angle (W / O Gearbox) - 1.8 °
    Holding Torque - 3Nm
    Rated Current / phase - 0.4A
    Phase Resistance - 30ohms
    Recommended Voltage - 12-24V
    Inductance - 34mH ? 20% (1KHz)
    Gearbox Type - Planetary
    Gear Ratio (Exact Gear Ratio) - 26 + 103/121
    Efficiency - 81%
    Backlash at No-load -
  • A4988 current limits and low-resistance motor selection
    #2 16300396
  • #3 16301942
    skosiu
    Rate: 8
    emarcus wrote:
    Rather choose a motor with lower resistance and lower voltage; say 1 to 3 ohms and 2 to 3 Volts.
    Earlier I didn't know that with A4988 I can use such low voltage motors. The specification contains the range 8V - 35V. It is good that you can connect with a lower voltage.
    Can you still tell me what is the formula for the value that I should set on the potentiometer for the following clinic?
    I think this one will do.
    17HS19-2004S1:
    Holding Torque - 59Ncm (83.6oz.in)
    Rated Current / phase - 2.0A
    Phase Resistance - 1.4ohms
    Voltage - 2.8V
    If the drivers keep warming up then it will be a change to DRV8825.
  • #4 16302875
  • #5 16302913
    Slawek K.
    Help: 259
    Rate: 1303
    emarcus wrote:
    It depends on the manufacturer of modules from A4988:
    You regulate the original POLOL differently, and their Chinese clones differently. They look the same and have the same pattern; they differ only in the value of the current measuring resistor.
    In Polol systems, the value of the reference voltage from the potentiometer is based on the formula V (in Volts) = 0.5 motor current (A), so for 1.5A current setting - you set Vref = 0.75 mV.
    For Chinese clones, often called 'stepStick' factor is 1.6; so for 1.5A current one should set Vref = 2.56V
    more info here: http://reprap.org/wiki/StepStick
    e marcus
    Buddy, this is how the current for the DRV8825 stepsticks is set, for A4988 the formula is:
    Vref = current * 8 * Rs
    Rs is the value of the measuring resistor, they vary depending on the manufacturer and are usually 0.2 or 0.1
    So for example for 1A current and resistor 0.1 it looks like = 1 * 8 * 0.1 = 0.8V
    pozdr
  • #6 16304422
    skosiu
    Rate: 8
    We substitute the motor or controller current in the formula?
    I understand that if I set V ref too low, nothing will happen. It's worse if I'm exaggerating the other way.
  • #7 16304463
    Slawek K.
    Help: 259
    Rate: 1303
    Motor current, just remember that the one given in DS is the maximum current. If you set too much, you will be able to fry scrambled eggs on the engine ;) the higher the current, the more the motor will heat up, except that for steppers from 60-80 degrees it is not critical. As too low, the engine can lose steps due to the resistance of the mechanical system in which it works.
    pozdr
The discussion centers around selecting a powerful stepper motor compatible with the Arduino CNC Shield and A4988 driver for a Z-axis application handling a load of approximately 3kg. The suggested motor, 17HS13-0404S-PG27, is a bipolar stepper with a holding torque of 3Nm, rated current of 0.4A, and operates within a voltage range of 12-24V. Users discuss the importance of balancing the load to reduce direct strain on the motor and the potential benefits of using a gearbox. Additionally, they explore the current settings for the A4988 driver, noting that the maximum current is limited to 1.0A without a heatsink and up to 2A with one. The conversation also touches on the DRV8825 as an alternative driver if overheating occurs. Proper adjustment of the potentiometer for current settings is emphasized, with formulas provided for both A4988 and DRV8825 drivers.
