Impact of 3rd Harmonic Reflection on CW PA Efficiency With 4:1 Combiner and LPF
351 10
How can I prevent the third harmonic from being reflected back into a push-pull CW power amplifier through a 4:1 combiner and low-pass filter without changing the cable phase length?
Use a parallel LC trap tuned to the third harmonic between the amplifier and the cable/combiner so the amplifier sees a high impedance at that frequency and is isolated from the reflected harmonic energy [#21684929] The LC product sets the resonant frequency, and the L/C ratio plus Q determine the series impedance at the harmonic [#21684929] This is the same general idea used in class E power amplifiers [#21684929]
  • 3rd harmonic reflection reducing PA efficiency
    #1 21684928
    John Soliday
  • #2 21684929
    PeterTraneus Anderson
  • #3 21684930
    sattamatka tips
  • #4 21684931
    sattamatka tips
  • #5 21684932
    sattamatka tips
  • Off-topic web design advertisement
    #6 21684933
    Pankaj Kumar
  • #7 21684934
    PtTarsem Sharma
  • #8 21684935
    Joan Melda
  • #9 21684936
    John Soliday
  • #10 21684937
    jessewalter375
  • Maximum efficiency limits for PA combiner topologies
    #11 21684938
    jessewalter375
The discussion addresses efficiency degradation in high-power continuous wave (CW) push-pull power amplifiers (PAs) used for industrial applications, operating approximately 3 dB into compression to meet target efficiency. A 4:1 combiner with integrated low pass filter (LPF) is employed to achieve conducted emission specifications of -50 dBc. However, third harmonic reflections from the combiner and LPF are reflected back into the PAs, causing an approximate 8% efficiency reduction. One proposed solution is the insertion of an LC parallel resonant circuit tuned to the third harmonic frequency between the amplifier and the cable, which isolates the PA from reflected third harmonic energy by presenting high impedance at that frequency. Adjusting phase length via cable has shown improvement but is currently not feasible. Additional attempts include using absorptive filters at the PA outputs before an in-phase combiner with low pass characteristics. Theoretical maximum efficiencies are noted as 25% for typical configurations and up to 50% for transformer or inductively coupled configurations, highlighting the importance of harmonic management to optimize efficiency and reduce power losses.
