How to Digitally Measure Distance Between C-Arm X-Ray Tips With 2.5m Span and 2cm Play
369 9
How can I digitally measure the changing distance between the tips of a C-arm X-ray machine as it rotates and may open or close by up to 2 cm?
A practical approach is to use a non-contact distance sensor system, such as a Parallax PING ultrasonic sensor read by an MCU, which measures about 2 cm to 3 m and outputs a pulse width proportional to distance [#21685569][#21685570] If you need real-time measurement while the patient is between the arms, the sensing hardware would need to be mounted with a physical offset on the machine, because ultrasound/light/radar methods cannot measure through the body [#21685568] If the C-arm motion is controlled by the machine itself, it may be possible to extract the position information directly from the machine instead of adding external sensors [#21685568] For the angle of the C-arm, a simple electronic level can give the overall tilt, but it will not resolve twisting or one-end shift by itself [#21685575] If only one end may move, a rigid platform at the rotation axis with target grids and cameras on each head was suggested as an experimental way to observe movement [#21685575]
  • Request for digital C-arm tip distance measurement
    #1 21685567
    Anthony Perera
  • Suggests extracting head position from machine control or using noncontact rangi
    #2 21685568
    Richard Gabric
  • Parallax PING ultrasonic sensor for 2 cm to 3 m range
    #4 21685570
    Giovanni Di Maria
  • #5 21685571
    Anthony Perera
  • Proposed grid x-ray test for arm movement
    #6 21685572
    Anthony Perera
  • Clarifying distortion and depth-of-field assumptions
    #7 21685573
    Richard Gabric
  • #8 21685574
    Anthony Perera
  • Suggests angle sensors and dual-camera target grids
    #9 21685575
    Richard Gabric
  • #10 21685576
    crossvid
A surgeon seeks a method to digitally measure the distance between the tips of a C-arm X-ray device, which can span approximately 2.5 meters with up to 2 cm of play, potentially causing image distortion. The C-arm moves vertically, horizontally, or at intermediate angles during imaging, and the user wants to verify if the distance between the arm tips remains constant or varies, contributing to distortion. Suggested solutions include using ultrasonic distance sensors, specifically the Parallax PING ultrasonic sensor, which measures distances from about 2 cm to 3 meters via sonar by timing echo returns. This sensor requires integration with a microcontroller unit (MCU) for operation. Additional considerations involve measuring the 3D position of the arms and background electromagnetic fields. The discussion also explores the possibility of angular displacement or twisting moments affecting the arm tips as the C-arm rotates, and the use of target grids and cameras to assess positional changes. Simple electronic angle levels may measure the C-arm angle but lack resolution for detecting tip twisting.
