How to Trigger 12V Piezo Horn From 8 Ohm 2W Phone Speaker Ring Signal?
582 6
  • Use a transistor driver to switch the 12V horn
    #1 21685668
    georgebaker
  • #2 21685669
    Chip Fryer
  • Measure speaker output and check meter bandwidth
    #3 21685670
    Richard Gabric
  • Use external ringer or relay off 30V ring signal
    #4 21685671
    David Ashton
  • #5 21685672
    mickbiden2
  • #6 21685673
    Giovanni Di Maria
  • Phone ringer relay options for analogue lines
    #7 21685674
    David Ashton
The discussion addresses how to trigger a 12V piezo horn from the low-level AC signal (0.035-0.045 VAC) across an 8 Ohm 2W phone ring speaker with no audio ports. The phone's ring signal is low voltage and likely pulse width modulated, complicating direct relay activation. Suggested solutions include using a sound-activated switch placed near the phone to avoid direct electrical connection, or tapping into the phone line itself with a high-impedance circuit involving a capacitor, bridge rectifier, and sensitive relay to detect the ring voltage (typically ~30 VAC on analog lines). For digital or VoIP phones, this method is not applicable. Another approach involves amplifying the ring signal with a transistor amplifier controlled by a microcontroller (MCU) that rectifies and scales the signal to 5V logic, then drives the 12V horn. Commercial external ringers designed for noisy environments can also be used. References to phone ring detector circuits using opto-isolators provide safe isolation from the phone line. Specific product recommendations include a Velleman phone ring detector module and a low-cost RJ12 phone cable-based ring detector available on eBay. Overall, the solutions focus on signal detection, isolation, amplification, and switching to drive a 12V piezo horn from a low-level phone ring signal.
