How to Use a Photocell to Trigger a Brighter Lamp When My Office Phone LED Lights Up
615 50
How can I use a photocell to detect my office phone’s LED and switch on a much brighter indicator light?
You can’t drive the brighter lamp directly from the photocell alone; the LDR’s resistance change is too small, so you need a transistor amplifier in between [#21666022][#21666023][#21666038] Start by using a plain red LED rated for about 20–30 mA, or a 10 mm SuperBright LED, instead of a filament bulb; the thread’s working build used a PN2222A transistor, with the flat face toward you giving emitter left, base middle, collector right [#21666043][#21666045][#21666060] The photocell goes in a light-tight pocket over the phone LED so no ambient light reaches it, and a trimpot is used to tune the trigger point; a 10 kΩ trimpot worked in the successful build [#21666045][#21666048][#21666050] If the LED stays on all the time or never turns on, adjust the trimpot until it switches cleanly between phone LED off and on [#21666045][#21666050] For a filament lamp, the replies warn you’d need a much higher-current driver and possibly a different transistor or a MOSFET, so the simpler and successful solution was to stay with an LED indicator [#21666030][#21666038][#21666058]
  • Photocell alone cannot switch a lamp directly
    #1 21666014
    George Mudrovich
  • Need transistor amplifier for LDR lamp trigger
    #2 21666015
    Rodney Green
  • #3 21666016
    William Makinen
  • #4 21666017
    Steve Lawson
  • Request for a word-based circuit diagram and transistor choice
    #5 21666018
    George Mudrovich
  • #6 21666019
    Rodney Green
  • #7 21666020
    Steve Lawson
  • Adjusting the 47 kΩ resistor to set LED threshold
    #8 21666021
    Steve Lawson
  • Photocell needs transistor amplifier for lamp drive
    #9 21666022
    Nick Brackenbury
  • Transistor switch recommended instead of driving lamp from LDR
    #10 21666023
    Shrikant Kamble
  • LEDs as light sensors for detection
    #11 21666024
    Mark Harrington
  • #12 21666025
    George Mudrovich
  • Green super bright LED recommended as light sensor
    #13 21666026
    Mark Harrington
  • #14 21666027
    Steve Lawson
  • #15 21666028
    George Mudrovich
  • Clarifying breadboard wiring, transistor, and lamp choice
    #16 21666029
    George Mudrovich
  • Breadboard identification and higher-current driver advice
    #17 21666030
    Steve Lawson
  • #18 21666031
    George Mudrovich
  • Possible component mismatch and trimpot clarification
    #19 21666032
    George Mudrovich
  • #20 21666033
    George Mudrovich
  • Breadboard orientation and transistor pinout question
    #21 21666034
    George Mudrovich
  • Clarifying photocell, transistor, and resistor roles
    #22 21666035
    George Mudrovich
  • Removing the 470-ohm resistor left lamp on continuously
    #23 21666036
    George Mudrovich
  • #24 21666037
    George Mudrovich
  • Use an LED for testing and verify transistor polarity
    #25 21666038
    Steve Lawson
  • Transistor current gain limits lamp drive
    #26 21666039
    Steve Lawson
  • Suggests measuring lamp current and replacing the transistor
    #27 21666040
    Steve Lawson
  • Requests updated circuit and specific LED specs
    #28 21666041
    George Mudrovich
  • #29 21666042
    George Mudrovich
  • Recommend a plain red LED and tweak base resistor
    #30 21666043
    Steve Lawson
The discussion centers on designing a circuit to detect when an office phone's LED indicator lights up and subsequently activate a much brighter lamp for better visibility. The original idea of directly connecting a photocell (LDR) in series with a lamp and battery is insufficient because the photocell's resistance change caused by the phone LED is too small to power a lamp directly. Multiple contributors recommend using a transistor amplifier stage, such as a single NPN transistor (e.g., PN2222A or BC548), to amplify the photocell signal and drive the lamp. The photocell used is a cadmium sulphide LDR with typical resistance values around 1kΩ in light and 10kΩ in dark, which is not low enough to power a lamp directly. A transistor circuit with appropriate base and collector resistors (e.g., 47kΩ and 470Ω) and a variable resistor (trimpot) for tuning sensitivity is advised. The transistor acts as a current amplifier, allowing a small current from the photocell to control a larger current to the lamp or LED. For initial testing and troubleshooting, it is recommended to use a low-current LED (e.g., a 10mm SuperBright LED rated for 20mA) instead of a filament lamp, as filament lamps require higher current and more complex driving circuitry. The transistor pinout and orientation are important, with the emitter, base, and collector identified for the PN2222A transistor. The photocell should be placed in a light-tight enclosure over the phone LED to prevent ambient light interference. The final working prototype used a 10k trimpot to adjust sensitivity, successfully turning an LED on and off in response to the phone LED. Scaling up to a brighter lamp would require consideration of the lamp's voltage and current specifications and possibly a more robust transistor or additional amplification stages. The use of Darlington transistors or MOSFETs was suggested for higher sensitivity or current handling. The discussion also touched on alternative light detection methods, such as using LEDs as light sensors or op-amp comparator circuits, but the transistor amplifier approach was the primary solution. Components were sourced from RadioShack and SparkFun, and solderless breadboards were used for prototyping. The final device was housed in a custom enclosure with the photocell mounted in a black suction cup pocket and the LED indicator placed with a parabolic reflector for visibility.
TL;DR: A phone LED won’t directly drive a bright lamp because an LDR typically ranges ~160 Ω (bright) to ~160 kΩ (dark); “The transistor is a current amplifier.” Wire an LDR to bias a PN2222A (or similar) and drive an LED or transistorized lamp. [Elektroda, Nick Brackenbury, post #21666022]
Why it matters: This simple add‑on turns a tiny phone LED into an unmistakable visual alert for missed calls, even in bright offices.
What problem does the simple LDR-only circuit have?
An LDR alone never falls to zero ohms, so phone LED light won’t supply enough current to a lamp. You need a transistor stage to amplify the photocell’s small change into a larger load current. Without amplification, the lamp stays dim or off because the LDR still limits current. [Elektroda, Steve Lawson, post #21666017]
How does the transistor make the lamp brighter?
The LDR and resistor set a base current for an NPN (e.g., PN2222A). That small base‑emitter current controls a much larger collector‑emitter current to drive your indicator. As Steve notes, “The transistor is a current amplifier.” This lets a faint phone LED trigger a clearly visible lamp or bright LED. [Elektroda, Steve Lawson, post #21666039]
Which parts should I buy to replicate the working solution?
Use an LDR, PN2222A (or MPS2222A), one 470 Ω resistor, a 1–5 kΩ trimpot for threshold, a red LED (20–30 mA), and a 9 V supply. This combination was tuned on a solderless breadboard and verified to work as a phone‑LED trigger with adjustable sensitivity. [Elektroda, Steve Lawson, post #21666046]
What is the PN2222A pinout so I don’t wire it backwards?
With the flat face toward you and leads pointing down, the pins are Emitter (left), Base (center), Collector (right). Reversing pins often makes the circuit fail silently, so match this orientation on your breadboard before powering. [Elektroda, Steve Lawson, post #21666046]
How do I set the trip point so it only triggers on the phone LED?
Install a trimpot in place of the base resistor, set midway, then: cover the LDR (LED off) and confirm your indicator is off; uncover or aim it at the phone LED and slowly adjust until the indicator turns on; recheck both states. This three‑step tune‑up was used successfully in the build. [Elektroda, Steve Lawson, post #21666046]
Can I use a filament bulb instead of an LED?
Yes, but it needs far more current and can overwhelm a small transistor. A PN2222A is rated up to about 600 mA, but practical use near 300 mA is safer without heavy thermal management. For higher current, move to a TIP102 or power MOSFET. [Elektroda, Steve Lawson, post #21666030]
Why did my filament lamp stay on all the time?
Replacing the LED’s series resistor with a wire can overdrive or damage the transistor, shorting collector‑to‑emitter and forcing the lamp on permanently. Restore proper current limiting and retest with an LED first to confirm the control path works. [Elektroda, Steve Lawson, post #21666040]
What’s an edge case I should watch for with filament bulbs?
Cold filaments draw a surge current (low cold resistance). Even a series 10 Ω may not help, because the filament may never heat enough while the transistor limits current. This can stall illumination or stress parts. [Elektroda, Steve Lawson, post #21666039]
How bright should my indicator LED be for office use?
A 10 mm SuperBright LED at ~20 mA with a ~40° viewing angle gives an eye‑catching cue without heavy power draw. It’s a drop‑in upgrade over a standard 5 mm LED for better visibility across your desk. [Elektroda, Steve Lawson, post #21666060]
Will this actually work on a real desk phone LED?
Yes. The project reached completion and was reported working at the office: the phone’s LED reliably triggered a bright red indicator once tuned with the trimpot and light‑shielded LDR placement. [Elektroda, George Mudrovich, post #21666063]
How should I mount the LDR to avoid false triggers?
Enclose the LDR in a light‑tight “pocket” or small tube over the phone LED so only that light reaches it. Seal the rear to block ambient light leaks, then tune the threshold with the trimpot. [Elektroda, Steve Lawson, post #21666046]
What is an LDR?
An LDR is a light‑dependent resistor whose resistance drops with light. Typical values span ~160 kΩ in darkness to ~160 Ω in strong light, but a small phone LED may only lower it to a few kilohms. [Elektroda, Nick Brackenbury, post #21666022]
What if my LED indicator never turns on?
Confirm PN2222A orientation, restore a 470 Ω series resistor with the LED, then adjust the trimpot. If still off, measure LDR resistance over the phone LED (on/off) to verify a clear resistance change. [Elektroda, Steve Lawson, post #21666048]
Can I swap the LDR for a phototransistor or LED-as-sensor?
Yes. A photo‑Darlington transistor increases sensitivity and reduces parts count, improving trigger reliability with weak light sources like phone LEDs. Re‑bias the base path as needed. [Elektroda, Steve Lawson, post #21666027]
Is there a quick 3‑step build-and-tune guide?
  1. Breadboard LDR→bias→PN2222A→LED with 470 Ω and a 1–5 kΩ trimpot. 2. Light‑shield the LDR on the phone LED. 3. Power up and trim until the LED toggles cleanly with the phone LED. [Elektroda, Steve Lawson, post #21666046]
How long will it run without failing?
After tuning, the LED‑driven build ran reliably in office use. As one helper noted, if it works for 10 minutes, it should run for hours; monitor heat if you later scale to larger lamps. [Elektroda, Shrikant Kamble, post #21666062]
