Designing Multistage Amplifier for 200mW Output to 8Ω Speaker From 20mV Mic Input
489 8
  • Concern about low base resistances and 92 µF capacitor feasibility
    #1 21685799
    MostevilJoeJoe
  • #2 21685800
    David Ashton
  • #3 21685801
    Maurizio Di Paolo Emilio
  • Use overall negative feedback for better amplifier performance
    #4 21685802
    Richard Gabric
  • Preferred values and complementary output stage advice
    #5 21685803
    David Ashton
  • #6 21685804
    johnpery
  • Multistage amplifier uses cascaded gain stages
    #7 21685805
    Jon marshal
  • #8 21685806
    taareni9
  • #9 21685807
    Keonte45
The discussion centers on designing a multistage BJT amplifier to deliver 200 mW average power into an 8 Ω speaker from a 20 mV peak-to-peak microphone input with a 500 Ω source resistance. The amplifier must maintain a frequency response from below 50 Hz to above 20 kHz. The original circuit achieves a gain of 21 V/V with stable, undistorted output, but concerns were raised about low base resistor values potentially damaging transistors and the practicality of a 92 µF output capacitor. Recommendations include using overall negative feedback to improve gain stability and performance, selecting standard preferred resistor and capacitor values (e.g., 47 kΩ instead of 48 kΩ, 100 µF instead of 92 µF), and employing capacitor bypassing on base resistors to balance DC bias and AC gain. The highest power dissipation is expected in the emitter follower stage, which should be checked carefully. The concept of cascaded amplifiers and cascode configurations was also mentioned as relevant multistage amplifier topologies. Additionally, integrated amplifier ICs designed for similar applications were suggested as alternatives to discrete BJT designs.
