100W Transistor Audio Amplifier Schematic with Mic Input and 3-Band Equalizer Design
354 11
How can I start building a transistor-only 100W audio amplifier with mic input and bass/mid/treble tone control?
Start by learning basic electronics first, because a 100W amplifier is a big project for a beginner [#21668585] Look up existing 100W audio amplifier projects and study beginner resources such as learnabout-electronics.org, allaboutcircuits.com, and electronics-tutorials.ws before trying to design your own [#21668585] The full system is not just a power amp; it is several blocks combined, including a mic preamp, headphone preamp, predriver, mixer, tone control, after-tone driver, power amp, and power supply [#21668582] Build and understand those sections one at a time rather than trying to assemble everything at once [#21668582] One reply also points to a transistor power amplifier schematic using MJ15003/MJ15004 as a starting reference [#21668579]
  • Request for transistorized 100 W stereo amp design
    #1 21668578
    Bong Chongki
  • #3 21668580
    Steve Lawson
  • #4 21668581
    Mark Harrington
  • #5 21668582
    iqbal Khan
  • #6 21668583
    Mark Harrington
  • #7 21668584
    Mark Harrington
  • Recommend learning basic electronics before 100W amplifier build
    #8 21668585
    Frank Bushnell
  • #9 21668586
    Mark Harrington
  • #10 21668587
    Frank Bushnell
  • Cost argument for paid PCB design work
    #11 21668588
    Mark Harrington
The discussion centers on designing a 100W transistor audio amplifier with stereo output (50W per channel), microphone input, and a 3-band equalizer (bass, mid, treble). The original poster requests a schematic without integrated circuits, covering a frequency range approximately 20Hz to 20kHz. Responses include a direct link to a 100W transistor amplifier schematic using MJ15003 and MJ15004 transistors. Contributors highlight the complexity of such a project for beginners, emphasizing the need for foundational electronics knowledge before attempting a large-scale design involving multiple stages: microphone preamplifier, headphone preamplifier, pre-driver, audio mixer, tone control, power amplifier, and power supply. Suggestions include studying basic electronics through free online courses and starting with simpler projects. Some responses note the practicality of purchasing ready-made amplifiers due to cost and design challenges. The discussion also touches on the difficulty of obtaining free professional design help and the value of investing time in learning electronics fundamentals.
TL;DR: Building a 100 W transistor audio amp is ambitious, and “A 100 Watt amplifier is a BIG project for a beginner.” [Elektroda, Frank Bushnell, post #21668585] Why it matters: This FAQ helps first‑time builders decide whether to DIY, what blocks are required, and where to find a 100 W schematic, mic input, and 3‑band EQ guidance.
What does a 100 W stereo (2×50 W) transistor amplifier project actually include?
You’ll build multiple stages: mic preamp, head preamp, pre‑driver, mixer, tone control, driver, power amp, and a power supply. Each stage needs biasing, noise control, and gain budgeting. Plan PCB layout, grounding, and heat sinking early. Keep channels identical for stereo balance. This is a large, multi‑week undertaking if you’re new. [Elektroda, iqbal Khan, post #21668582]
Is this a good first project if I’m just starting electronics?
No. Learn fundamentals first, then attempt smaller amps to build skills. Quoting an expert reply: “A 100 Watt amplifier is a BIG project for a beginner.” Start with low‑power headphone or 10 W modules to practice biasing and troubleshooting. That foundation saves parts and time later. [Elektroda, Frank Bushnell, post #21668585]
Where can I see a 100 W all‑transistor schematic?
The thread includes a reference schematic link using MJ15003/MJ15004 output transistors. Review it to understand typical stages, protection, and bias networks. Use it as a study aid before designing or building your own. Check transistor pinouts and safe operating area if you replicate it. [Elektroda, Mark Harrington, post #21668579]
How do I add a microphone input without using ICs?
Use a discrete mic preamp stage ahead of the main preamp. Design for appropriate gain and noise performance, and include input impedance suited to your mic type. Add DC blocking, filtering, and shielding. Route mic grounds carefully to avoid hum. Then mix the mic path with line sources before tone control. [Elektroda, iqbal Khan, post #21668582]
What is a 3‑band equalizer (bass/mid/treble) in this context?
A 3‑band EQ is a tone‑control network that lets you boost or cut low, mid, and high frequencies before the power amp. In discrete builds, it sits after preamps and before the driver stage. Choose component values to set corner frequencies, and verify with a signal generator and scope. [Elektroda, Bong Chongki, post #21668578]
How do I break the design into manageable steps?
  1. Prototype each block separately (mic pre, preamp, tone control, driver/power).
  2. Verify gain, noise, and frequency response per block, then add the mixer.
  3. Integrate blocks sequentially, testing after each connection; finish with the PSU and full‑power checks. [Elektroda, iqbal Khan, post #21668582]
I typed 20kHz–20kHz by mistake. What frequency range should I target?
The thread highlights that 20k–20k was a typo. Align your design goal to the audible band rather than a zero‑width band. Confirm your intended low‑frequency extension, then choose coupling and feedback components accordingly. Recheck test equipment bandwidth and calibration. [Elektroda, Steve Lawson, post #21668580]
Could buying an amp be cheaper than building this?
Yes. A reply notes you can buy a finished amplifier inexpensively online. DIY teaches a lot, but parts, tools, time, and rework can exceed a bargain unit’s price. Consider your goals: learning versus immediate use. Factor serviceability and documentation into your choice. [Elektroda, Mark Harrington, post #21668583]
What is a ‘pre‑driver’ or ‘driver’ stage in a power amp?
The pre‑driver boosts voltage and prepares the signal for the driver, which supplies current to control the output transistors. Together, they set open‑loop gain, bandwidth, and stability. Correct biasing prevents crossover distortion and thermal runaway in the output stage. [Elektroda, iqbal Khan, post #21668582]
What skills or study path should I follow before attempting 100 W?
Study component behavior, biasing, feedback, grounding, and audio measurement. Work through beginner courses and build smaller circuits first. As one mentor advises, read basics so circuits work almost the first time you power them. Practice measurement and fault‑finding on low‑risk builds. [Elektroda, Frank Bushnell, post #21668585]
What mixer functionality do I need for mic plus line sources?
You need level controls and summing before the tone control. Place the mic preamp first, then use a passive or active mix node to combine sources. Maintain headroom to prevent clipping, and include attenuation for hot inputs. Keep cables short to reduce noise. [Elektroda, iqbal Khan, post #21668582]
Any edge cases I should plan for during testing?
Yes. Large discrete amps can oscillate or burn output devices if bias or wiring is wrong. Use current‑limited bench supplies and a dim‑bulb tester on first power‑up. Verify each block in isolation to limit damage. Document changes before full‑power tests. [Elektroda, Frank Bushnell, post #21668585]
Can I get community help if I get stuck?
Yes. The thread shows multiple contributors offering humor, cautions, and resources. Ask specific questions with schematics, voltages, and scope captures. Be ready to learn and iterate. Respect time and feedback to keep conversations productive. [Elektroda, Frank Bushnell, post #21668587]
What did the original requester actually want to build?
They asked for a 100 W stereo amplifier (2×50 W), with a microphone input, 3‑band equalizer, and fully transistorized design. They sought schematics and guidance to begin. Use their spec as a starting brief if you replicate the project goals. [Elektroda, Bong Chongki, post #21668578]
Is there a quick reality check before I commit?
Count required blocks and your available tools. One reply lists mic pre, head pre, pre‑driver, various mixers, tone control, post‑tone driver, power amp, and PSU—seven plus stages. That scope demands time, test gear, and patience. Plan accordingly. [Elektroda, iqbal Khan, post #21668582]
Any closing perspective from the thread?
The discussion veers into cost and effort debates, plus a shared schematic link. Filter the noise, extract the requirements, and proceed stepwise. Document your build to simplify debugging and future upgrades. [Elektroda, Mark Harrington, post #21668579]
