How to Boost LM386 Audio Amplifier Output Using TIP147 and TIP142 Transistors?
1002 10
How can I get my LM386 microphone amplifier to work properly and increase its output using power transistors?
You need a microphone preamp/booster before the LM386; the problem is the mic signal level, not the power amplifier itself [#21674876] For an electret mic, use the suggested preamp circuit, connect the mic body to ground/negative, and make sure the base-emitter voltage is about 0.6 V; if it is lower, change the 82 kΩ resistor to 68 kΩ [#21674876][#21674878] Do not feed a laptop line output into the mic input stage, because line level is much higher; use a 2.2 µF coupling capacitor in series with the source and then a 22 kΩ or 33 kΩ resistor, or a 47 kΩ preset, to reduce the input level [#21674880] If the circuit distorts, restore the original component values, use the correct biasing, set R10 to 1 kΩ to bias the output at half the supply voltage, and add heatsinks to the TIP31/TIP147/TIP142 output devices [#21674882] Also, use a suitable speaker load, such as 8 Ω / 20 W, rather than forcing a 40 W speaker on this small amplifier [#21674882]
  • #1 21674874
    usama khurram
  • #3 21674876
    Sambath Kumar
  • #4 21674877
    usama khurram
  • #5 21674878
    Sambath Kumar
  • Distortion at 4.5 V, 450 mA output level
    #6 21674879
    usama khurram
  • Reduce laptop output with 2.2 µF and 33 kΩ attenuator
    #7 21674880
    Sambath Kumar
  • TIP31 overheating with 15 V supply and 4 Ω load
    #8 21674881
    usama khurram
  • Add coupling capacitor, lower supply to 15 V, and rebias output stage
    #9 21674882
    Sambath Kumar
  • #10 21674883
    usama khurram
  • #11 21674884
    usama khurram
The discussion addresses improving the output of an LM386 audio amplifier when used with a microphone, focusing on integrating power transistors like TIP147 and TIP142 or Darlington pairs for higher amplification. Key advice includes adding a preamplifier stage to boost the microphone signal before feeding it into the LM386 amplifier, as the mic signal alone is too weak. Suggested components for the preamp include 2N3904 transistors and proper biasing with resistors (e.g., adjusting from 82k to 68k) and coupling capacitors (2.2 µF) to prevent DC distortion. Users reported issues with distortion and overheating of TIP31 transistors when using higher supply voltages or currents, recommending lowering supply voltage to around 15V, adding series resistors (4.7 Ω, 10W), and using heat sinks. Proper biasing and component values (e.g., R9, R10 resistors) are critical for stable operation. The discussion also highlights the difference between mic-level signals (50-60 mV) and line-level signals, emphasizing the need for a preamp for microphone input. Attempts to increase output power to about 25 watts require careful transistor selection and thermal management. Additional suggestions include using a 47k preset resistor for volume control to reduce distortion and ensuring the electret microphone body is grounded. The conversation also touches on troubleshooting intermittent operation related to the 2N3904 transistor and requests for sound-reactive LED circuits compatible with the amplifier setup.
