Calculating Resistance and Current for 50W and 100W Lamps in Series on 240V Circuit
534 9
How do you calculate the resistance of 50 W and 100 W lamps and the current when they are connected in series across 240 V?
Assuming both lamps are rated for 240 V and using their hot (nameplate) resistances, the 50 W lamp is 1152 Ω and the 100 W lamp is 576 Ω, giving a total series resistance of 1728 Ω and a circuit current of about 0.139 A [#21686033] In real life, incandescent lamps are non-ohmic, so their resistance changes with temperature and the series current will not match the simple calculation exactly [#21686025][#21686026] Because of that, the simple Ohm’s-law result is only a theoretical answer unless the lamp characteristics are measured [#21686025][#21686026]
  • #1 21686024
    Len32520
  • Series lamps will not match rated resistance
    #2 21686025
    Richard Gabric
  • Cold resistance limits current in series bulbs
    #3 21686026
    David Ashton
  • #4 21686027
    Chris Sheridan
  • Incorrect use of lamp ratings as fixed resistance
    #5 21686028
    Len32520
  • Need bulb rating basis before solving series circuit
    #6 21686029
    Richard Gabric
  • Series-bulb calculation assumes hot resistance incorrectly
    #7 21686030
    David Ashton
  • #8 21686031
    Len32520
  • Clarify whether lamp wattage is steady-state or rated at 240V
    #9 21686032
    toddcarmay
  • Series lamp resistance calculation gives 139 mA current
    #10 21686033
    SiaGomez
The discussion addresses the theoretical calculation of resistance and current for two incandescent lamps rated at 50W and 100W connected in series across a 240V supply. Using the power rating and voltage, resistance for each lamp can be estimated by R = V² / P, yielding approximately 1152 ohms for the 50W lamp and 576 ohms for the 100W lamp. The total series resistance sums to about 1728 ohms, resulting in a circuit current of approximately 0.139 A. However, practical considerations highlight that incandescent lamps are non-ohmic devices with resistance varying significantly between cold and hot states. When connected in series, the lamps do not operate at their rated voltages or powers, causing uneven voltage drops and current flow, with the lower wattage lamp limiting current and the higher wattage lamp potentially not reaching full operating temperature. This makes real-world calculations complex and theoretical results approximate. The consensus is that such series connections are not typical for lamps designed for parallel operation at 240V, and experimental verification or detailed lamp characteristic data is necessary for accurate analysis.
