Best WiFi Network Card for PC Gaming: Top Models, Brands & Stable FPS with Low Ping
robo4422 11622 16
What PCI-E Wi‑Fi card should I buy for PC gaming if I need low ping and want support for 150–200 Mb/s later, but I can’t run an Ethernet cable?
For your case, a PCI-E 5 GHz AC card with external antennas and MIMO is the best compromise, e.g. Asus PCE-AC55; if you need something cheaper, PCE-AC51 was also suggested, but the budget is tight [#17036123][#17036864][#17037159] AC on 5 GHz is needed for 150–200 Mb/s, while 2.4 GHz N/b/g will be limited and more congested [#17034958][#17036958] Choose a card with a separate antenna panel on cables so you can place it away from the PC, and avoid no-MIMO models because they handle reflections and signal fades worse [#17036123] Keep in mind that 5 GHz through two walls is a bad idea, so ping can still spike if the signal path is poor [#17037013][#17034097] If possible, Ethernet is still the most stable solution; PLC was mentioned, but low-cost sets were said not to reach the needed 200 Mb/s [#17034097][#17037159]
  • #1 17033960
    robo4422
    Rate: 9
    As in the subject, I am looking for a good network card for my computer with a wifi antenna. I would like it to provide me with pretty good comfort during the game (stable fps with comfortable ping
  • #2 17034097
    Sztandar18
    Help: 75
    Rate: 104
    I struggled with the wifi network card (no matter what, with each problem will be) just by two walls in a distance similar to yours and advise, periodically will ping, but from time to time you will have a wave of pingu> 300 ms and you will only get mad. If you have the option, buy a twisted pair and forget about the problem.
  • #3 17034124
    robo4422
    Rate: 9
    Well, but the problem is that I do not have the cable to run too much, because both rooms share a bathroom, and I will not run a cable around the bathroom because it would be on the outside: /
  • #4 17034157
    Sztandar18
    Help: 75
    Rate: 104
    I have one question. Do you have a smartphone eg on android or iOS (iphone)?
    We could check the signal level in this room where the computer with a wifi network card should stand.
    The android app for signal strength measurement is called Wifi Analyzer
  • #5 17034167
    robo4422
    Rate: 9
    I installed the application as you recommended. When I put my phone where it should be, the antenna shows me the power at -65 / -70 [dBm]
  • #6 17034603
    makosuu
    Help: 369
    Rate: 370
    robo4422 wrote:
    power level -65 / -70 [dBm]
    It's good. For speeds up to 20Mbps, you can even buy a b / g card and buy it. Any budget?
  • #7 17034626
    robo4422
    Rate: 9
    In total, I did not want to spend too much on this card, I think that up to 60-80 PLN max. For half a year I intend to increase the internet speed to 150-200mb, so when choosing, I have to suggest support for such speeds, although I will not download anything there, I care more about constant ping and low lag in games
  • #8 17034958
    makosuu
    Help: 369
    Rate: 370
    Mb / s
    You will need 5Ghz AC for such speeds.
    WHAT DO YOU HAVE ROUTER?
    This card should be git:
    http://allegro.pl/hit-tp-link-usb-2-0-ac600-archer-t2uh-usb-fv-24h-i6920615376.html
    Future has AC but without MIMO.
    This is also yours, for PCI-E it's better, but there is no AC.
  • #9 17035050
    robo4422
    Rate: 9
    But I would like to buy something on pci-e and what is AC?
  • #10 17035058
    makosuu
    Help: 369
    Rate: 370
    robo4422 wrote:
    What is AC?
    Much faster WiFi standard in the 5 GHz band. AC cards for PCI-E are more expensive, and you write about 150Mbps which on your offer will be impossible to achieve. But if you want to take it, you will not be fooled.
  • #11 17035132
    robo4422
    Rate: 9
    And what is your recommendation for 5gz standard pci?
  • #12 17036123
    Nagus
    Help: 99
    Rate: 97
    E.g. Asus PCE-AC55.
    In my opinion, it is good when the card has a ready panel with antennas on the cables so that you can drag them from behind your desk.
    No cards without MIMO - they cope less with reflected signals and are more sensitive to signal fades.
  • #13 17036864
    makosuu
    Help: 369
    Rate: 370
    Not this budget.
    PCE-AC51 is also good at Allegro from PLN 115. But still a little above.
  • #14 17036958
    Nagus
    Help: 99
    Rate: 97
    Either the colleague wants performance or breaking up. With the crowded 2.4GHz band, it will be difficult to draw the appropriate parameters for playing or watching TV. N 5GHz do not make sense, because AC are not that much more expensive (at least 2x2, because 3x3 card prices can already be cosmic), and have higher bandwidth and beamforming, which can noticeably raise the signal.
    As Asus is too expensive, maybe Chinese people have something interesting.
    And the problem is presented like this:
    I am looking for a car that would drive like BMW but I have the budget for Skoda Fabia.
    Then a desperate thread will be created:
    Help me, I have Fabia and any luj in Golf leaves me at the lights!
  • #15 17036985
    makosuu
    Help: 369
    Rate: 370
    I gave the above card with AC without MIMO which is in the budget, and I think that is enough. But what ultimately will be purchased depends on the author of the topic.
  • #16 17037013
    geniusm
    Help: 70
    Rate: 49
    5GHz on two walls is a bad idea. Maybe you would be interested in PLC?
  • #17 17037159
    KOCUREK1970
    Help: 3861
    Rate: 5489
    PLC - the idea is good, only the author wants to raise the speed to 200 Mb and that on a low-cost set he will not get, he has to spend 500 PLN on the PLC.
    Nagus wrote:
    Asus PCE-AC55.
    Road card - but I have and recommend it myself.
The discussion revolves around selecting a suitable WiFi network card for PC gaming, emphasizing the need for stable FPS and low ping. Users express concerns about signal strength and latency, particularly when walls obstruct the signal. Recommendations include using a PCI-E card with 5GHz AC support for higher speeds, with specific models like Asus PCE-AC55 and PCE-AC51 mentioned. The importance of MIMO technology for better performance in reflected signals is highlighted. Users also discuss alternatives like PLC (Powerline Communication) for improving connectivity without running cables.
TL;DR: Planning 150–200 Mb/s and low ping? "You will need 5GHz AC for such speeds." A budget USB AC adapter can work, though without MIMO. [Elektroda, makosuu, post #17034958]
Why it matters: PC gamers behind walls need the right WiFi standard to avoid lag spikes and wasted upgrades.
What WiFi card should I buy for PC gaming under 80 PLN?
Stay with a budget USB AC600, like TP‑Link Archer T2UH. It supports AC on 5 GHz but lacks MIMO. That keeps cost low and enables future AC routers. Expect lower peak throughput than PCIe MIMO cards. [Elektroda, makosuu, post #17034958]
Do I need 802.11ac for 150–200 Mb/s internet?
Yes. “You will need 5GHz AC for such speeds.” 2.4 GHz solutions struggle at these rates, especially in crowded bands. Choose AC-class hardware. [Elektroda, makosuu, post #17034958]
What is “AC” and why does 5 GHz help gaming?
AC is a much faster WiFi standard in the 5 GHz band. It offers higher throughput and less interference than 2.4 GHz. That helps latency-sensitive games. [Elektroda, makosuu, post #17035058]
Is 5 GHz good through two walls for gaming?
No. “5GHz on two walls is a bad idea.” Attenuation and reflections can raise latency and drop rates. Consider Ethernet or PLC as alternatives. [Elektroda, geniusm, post #17037013]
How do I measure my WiFi signal to decide on a card?
  1. Install WiFi Analyzer on Android.
  2. Stand where the PC will sit and note the SSID’s dBm value.
  3. Repeat at different heights/angles to find the strongest spot for antennas. [Elektroda, Sztandar18, post #17034157]
Is −65 to −70 dBm enough for smooth gaming?
That level is considered good. It can handle up to about 20 Mb/s on b/g. For higher speeds, use 5 GHz AC and better antennas. [Elektroda, makosuu, post #17034603]
Why should I avoid non‑MIMO WiFi cards?
“No cards without MIMO – they cope less with reflected signals and are more sensitive to signal fades.” MIMO improves stability and effective throughput. [Elektroda, Nagus, post #17036123]
Which PCIe WiFi card is recommended for 5 GHz gaming?
Asus PCE‑AC55 is a solid pick. A cabled antenna panel helps position antennas away from desk obstructions for cleaner signal. [Elektroda, Nagus, post #17036123]
What’s the cheapest viable PCIe option if I can stretch budget a bit?
Asus PCE‑AC51 is a good entry choice around 115 PLN. It exceeds an 80 PLN cap but improves over USB sticks. [Elektroda, makosuu, post #17036864]
Are USB adapters like TP‑Link Archer T2UH OK for gaming?
They can work if budget is tight. Archer T2UH is USB 2.0 AC600 and lacks MIMO. Expect reasonable play, not maximum throughput or range. [Elektroda, makosuu, post #17034958]
Should I consider powerline (PLC) instead of WiFi for low ping?
Yes, especially through walls. PLC is a good idea, but for ~200 Mb/s you need better kits. Budget about 500 PLN to avoid bottlenecks. [Elektroda, KOCUREK1970, post #17037159]
Why do I get sudden ping spikes on WiFi even with decent signal?
Walls and interference cause bursts. Users report waves of ping over 300 ms in similar setups. Run Ethernet if possible to eliminate spikes. [Elektroda, Sztandar18, post #17034097]
