Where to download recovery firmware for Thomson 55UG6300 MS6586?
ChrisTv08 414 4
  • Requesting exact USB recovery file and preparation details
    #1 21923131
    ChrisTv08
    Mark: THOMSON
    Model: 55UG6300
    Chassis: MS6586
    More information: Good morning, I come to ask for help to recover the firmware, if anyone could send the RECOVERY firmware file I would really appreciate it.​
    I already tried the procedure of unplugging the TV and holding the power button while plugging it back in and it "says software file check failed", so I need to recover the firmware via USB.
    CURRENT SOFTWARE:V8-S586T07-LF1V020
    THANK YOU
    Could you please share the country/region of the TV and a photo or full text from the back label, including product code, serial number, panel code, or any “V8-...” / “TCL” identifiers?
    italy
    What exact recovery file did you try via USB, what was the filename, and how was the USB prepared/formatted when the TV showed “software file check failed”?
    I haven't tried USB yet, as I don't have the correct firmware file, I just tried the method I described.
  • #2 21923563
    flinc
    Level 30  
    Help: 93
    Rate: 155
    elektrotanya.hu
    On the SM SEARCH portal, simply type in ‘THOMSON’ and the service codes and EEPROM will be displayed
  • #4 21923773
    flinc
    Level 30  
    Help: 93
    Rate: 155
    @ChrisTV8 In G......just search for ‘THOMSON 55UG6300 TV service mode’
    is the standby LED lit? If not, check the power supply or search for ‘THOMSON 55UG6300 TV’ on eBay
    eBay will display parts for the THOMSON TV
  • #5 21924115
    ChrisTv08
    >>21923724 Already tried, the model isn't there unfortunately.
