HmIP-SWD not added to CCU2 - SGTIN correct, 'Next' button not active
TomiMX 369 0
  • Possible prior pairing or account lockout issue
    #1 21750978
    TomiMX
    Pairing problem with HmIP-SWD flood sensor (CCU2)
    Hi everyone! I have a problem with adding a new Homematic IP flood sensor (HmIP-SWD) to my CCU2 control panel.
    I am counting on your experience!
    Description of the problem
    Detection: I enter the search mode for a new device in the app (Android) and the sensor is detected automatically.
    Identification: At this stage, the app asks for the SGTIN code.
    SGTIN code: I checked and the code is identical in all places:
    On the sticker on the back of the sensor.
    On the sticker on the box
    On the sticker with the QR code.
    Lockout: After entering the SGTIN code correctly (certainly without typos!), the "Continue" / "Continue" / "Finish" button remains inactive / grayed out.
    It looks as if the system thinks that the code entered is incorrect.
    Which I have already done (unsuccessfully):
    Sensor reset: I performed a hard reset of the flood sensor (removing and re-inserting the battery with the button pressed).
    Code check: I have checked the SGTIN code multiple times, typing it in manually and making sure there are no spaces or errors.
    Question for you: What could be the cause?
    Thanks in advance for your help!
    AI: What version of software (firmware) does your CCU2 control panel have and what version of the Homematic IP app are you using on Android?
    CCU2 - 3.0.36
    APP - 3.6.14
    AI: Has this sensor been previously added to another control panel or Homematic IP account, or has it been used by someone else before you?
    I have no knowledge, I bought it on an auction portal
