Smart Life - lighting scenes don't always trigger at sunset. What to do?
Asteroid 642 1
  • Checking whether missed sunset scenes retrigger after reconnect
    #1 21783654
    Asteroid
    Help: 18
    Rate: 188
    Hi I have a Smart Life application. I have scenes programmed for exterior house lighting on controllers mounted in the box front of house and side of house. A simple scene - switching on the outside lights at sunset and switching off the lights at 11 p.m. Switching on the lights before sunrise 1 hour and switching off at sunrise. Immediately after installation everything worked as it should but recently it happens that it will not switch on the outdoor lighting at sunset on both controllers. Yesterday it did not switch on the outdoor lighting according to the scene.I manually switched it on from the app and it automatically switched off at 11 p.m. In the morning it worked according to the programmed scene correctly.I am wondering what is the reason that this sometimes happens and how to fix it. I have notifications enabled when the drivers are offline and there was no message so rather they were in range. I'm wondering when I have a scene programmed to turn on the controllers at sunset, let's say the sun sets at 3.30pm and then when it temporarily loses range and doesn't turn on at 3.30pm, if the range comes back e.g. at 3.40pm should it turn on according to the scene. How do I check this? What is the cause, maybe something needs to be changed in the application Please advise
  • #2 21791575
    Sunnysky
    Maybe the longest night and lowest sun angle have something to do with detecting sunrise.
