ESP12 - how to improve WiFi signal strength and increase the range of the module?
JORGEN1970 345 6
  • 12 dB antenna did not improve ESP12 signal
    #1 21784469
    JORGEN1970
    Rate: 18
    How do I increase the signal strength of the WiFi ESP12?
    Hello, I need help with the issue of increasing the signal strength between two ESP12 modules.
    For this purpose I have purchased the larger 12 dB antenna shown in the picture:
    Added after 1 [minute]:
    Two WiFi antennas with SMA connectors and cables on a white surface
    However, using this larger 12 dB antenna did not increase the signal strength compared to this smaller antenna shown in the photo, in fact even using the 12 dB antenna has less signal strength.
    I'll show the tips more closely, maybe some wave matching needs to be applied. Please give me your ideas:
    SMA female and male antenna cable connectors with a black WiFi antenna
  • #2 21784478
    Adam Walko
    Help: 218
    Rate: 460
    JORGEN1970 wrote:
    How to increase signal strength
    How much does it currently have?
    How much do you owe yourself?
  • #3 21784480
    JORGEN1970
    Rate: 18
    I currently have about - 90 dB , if I had about - 80 dB that would be enough.
    Communication outside but basement and 1st floor about 30 to 40 m after obstructs the corner of the block.
  • #4 21784490
    Adam Walko
    Help: 218
    Rate: 460
    Look for a range of amplifiers! I don't know how rich you are?
  • #5 21784497
    tos18
    Help: 1113
    Rate: 1870
    Doesn't your module have a jumper to select internal / external antenna like the wemos D1 Mini PRO ?
    Wemos D1 Mini Pro board with antenna selection jumper highlighted
  • #6 21784932
    JORGEN1970
    Rate: 18
    WiFi ESP-12 module with purple M marking and u.FL antenna connector
    I have a WIFI ESP12 with input for the antenna.
  • #7 21787647
    JORGEN1970
    Rate: 18
    Adam Walko wrote:
    Look for the amplifiers on offer! I don't know how rich you are?
    On what principle do such amplifiers work , ie do they amplify all signals or just dedicated ones? How does it work?
