Hello, I am building a Home Assistant for the first time. It will be controlling a home greenhouse. There will be an ESP plugged in and STH30 sensors connected via RS-485. I want to use a mini PC I don't need as a server, but unfortunately it doesn't have built-in Wi-Fi, only when I had Win7 I used USB Wi-Fi. And here is the problem, how to bite it to have Wi-Fi.... Because I've already connected one Wi-Fi, but HA doesn't detect it, and do you know any model of USB Wi-Fi that will work under HA?
pkpintercity
pkpintercity
Rate: 58
