Sonoff and Ewelink are going crazy - disconnecting for no reason.
Reshala 984 15
Why do my Sonoff and eWeLink devices randomly go offline on 2.4 GHz Wi‑Fi, and what can I do to stop it?
The thread points to a problem with the 2.4 GHz Wi‑Fi side of the network, not the Sonoff devices themselves: possible causes mentioned were a broken router or heavy 2.4 GHz interference [#21834525] You also found 29 active 2.4 GHz connections out of a 32-device limit, which suggests the band may be near capacity [#21834821] The main recommendation was to replace the repeater with a real access point connected by LAN, without NAT, and to set channels so they do not overlap [#21834941] One reply also said the Mercusys ME60X could be faulty and should be replaced, if needed [#21826779] A Deco X50 mesh/AP was suggested as a working example for many Ewelink and Tuya devices [#21835925]
  • Repeater reset restores offline Sonoff devices
    #1 21826775
    Reshala
    Level 4  
    Hello, I have pored over the smart stuff in my house, specifically this:
    - sonoff Dual R3 roller shutter controllers
    - lED drivers Sonoff Basic R2
    In addition, to improve the range, I have a Mercusys ME60X repeater
    The problem is that on random days and times it disconnects some devices in the eWeLink app, it just grays out and shows that the device is OFFLINE.
    This is strange because nothing is being buried, nothing is limiting coverage.
    Yes, after a while - sometimes longer, sometimes shorter - the problem resolves. If, on the other hand, I reset the repeater, then after the reset the problem is immediately solved and the devices are ONLINE.
    I don't know if it's the channels over Wi-Fi or what, but it's annoying already.
    Today was the 1st time that I got up at 6:00 am and the LEDs were on, which turn on at 8:00 pm in the evening and could not be turned off in the app because they were "OFFLINE"....
  • #2 21826779
    k45i89o98j66
    Help: 538
    Rate: 991
    Mercusys ME60X ustatly firmware update dated 2023-11-24.
    Were faulty replace repeater.
  • #3 21826781
    Reshala
    Level 4  
    Yes, it's just that not all the devices I mention are connected via a repeater....
    Some of them are connected directly to the Wi-Fi without a repeater, and still disconnect.
  • #4 21826790
    k45i89o98j66
    Help: 538
    Rate: 991
    and which router?
  • #6 21826856
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    1.Instead of a repeater, use an AP
    2. Instead of a Chinese cloud your own server and possibly your own VPN or Tailscale, Zerotier etc.
    And the problems will disappear
  • #7 21826970
    Reshala
    Level 4  
    1. I wrote that it's not just the devices that are further away, after the repeater, but also those that are closer to the base router.
    2. How do you make your own server for such things?
  • #9 21827161
    Reshala
    Level 4  
    Black magic for me... Another solution is needed.
  • 2.4 GHz router band appears broken while 5 GHz works
    #10 21829003
    Reshala
    Level 4  
    Okay, now here's the situation, I wanted to connect to the wifi on my phone at 2.4GHZ, can't, doesn't connect me....
    At the same time, ONLY those devices that are connected to the router on 2.4ghz (not to the repeater, but to the router) do not work.
    On the other hand, I can connect to a 5Ghz network without any problem, but the sonoff does not support it ... so it is something with the router and the 2.4ghz band.
    What is the issue, why doesn't the 2.4 band work but the 5Ghz band works and connects?
  • #11 21834084
    Reshala
    Level 4  
    No idea? it was the same today, same disconnection and no way to connect to wifi after 2.4ghz....
  • #12 21834525
    xury
    Help: 878
    Rate: 1498
    The ideas can be many. From a broken router to heavy interference on the 2.4GHz band
  • #13 21834821
    Reshala
    Level 4  
    according to ip scanner I have 29 active wifi device connections on 2.4ghz, according to the router I can have a maximum of 32 active connections, could this be from this ?
  • #14 21834941
    xury
    Help: 878
    Rate: 1498
    Well, you have answered yourself. Add an AP and set the channels appropriately so they don't overlap, split the traffic between the AP and the router. And it has to be a real AP, not a repeater. Unless your repeater can work as an AP. i.e. connected via LAN cable to the router and working without NAT.
  • #15 21834993
    Reshala
    Level 4  
    is there a cheap and good AP you recommend that can handle this?
  • #16 21835925
    binkom
    Help: 8
    Rate: 14
    Put a Deco X50 and it will work, I have 15 Ewelink and 25 Tuya. and 3 Deco
