2010 Skoda Octavia Facelift: Gen 2 Steering Box G85 Sensor Not Detected, Error Codes
madalin2401 717 2
  • VCDS basic setting attempted for G85 adaptation
    #1 21843854
    madalin2401
    Hello, I have problems with a 2010 Skoda Octavia facelift. I installed the Gen 2 steering box, I installed a steering wheel computer with a G85 sensor, but it still doesn't see the G85 sensor and I still have these errors
    AI: Can you provide the exact error codes you are seeing when the G85 sensor is not detected?
    02546, 00778,
    AI: Did you perform any coding or adaptation procedures (e.g., using VCDS or ODIS) after installing the Gen 2 steering box and G85 sensor? If so, what steps did you take?
    Am încercat setarea de bază cu VCDS
  • #2 21843986
    sigwa18
    Help: 1194
    Rate: 3359
    Regarding error 00778. haven't you undone the steering wheel/magic control connection sometimes (you have the steering wheel straight when driving straight ahead)? In the measurement blocks you see the values from the steering angle sensor (it changes when you turn the steering wheel)?
  • #3 21844089
    madalin2401
    Da, am volanul drept; în blocurile de operare nu se modifică nimic când rotesc volanul, rămâne 0.
