[Solved] VW Golf 5 2004: Power Steering Issue, Red Indicator On, Connection Error - Solutions Needed
goolfik 19500 6
  • #1 17092293
    goolfik
    I have a golf v car from 2004. Recently it happened to me that when I started the engine, the red indicator of the power steering turned on. Support is gone and I don't know what to do now. A connection error is displayed on the computer. the battery was checked, all the cubes and nothing helped. someone will help what to do?
    Moderated By CameR:
    Separated from:
    https://www.elektroda.pl/rtvforum/topic1690700.html
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, especially other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    Reg. 3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault.
  • #2 17092701
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Fuses checked?
    So there is no communication with the controller, or some specific error number?
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 17092804
    goolfik
    Fuses checked and everything ok. The computer only displays no connection.
    After driving 20 km without power steering, it suddenly unlocked and power steering came back. But when the engine is turned off, the red indicator light and no assistance are visible again
  • #4 17094644
    seba694637
    Help: 11
    Rate: 115
    Vcds error checking. Steering angle sensor adaptation, assist calibration
  • #5 17094729
    jurekk55
    Level 36  
    Help: 182
    Rate: 1579
    The factual check was performed perfectly.
    Now check the power supply, signals on the CAN cables.
    Finally, possibly
  • #6 17094730
    berthold61
    Help: 81
    Rate: 317
    Sometimes a weak battery can do such circuses, because the support is electro-oil, i.e. a high-power motor in the pump and one housing, check the plugs next to this pump should be three and if any has escaped or any cable, and check if there is anything in it or if there is Anything else oil?
  • #7 17131332
    goolfik
    unfortunately it was necessary to change the steering gear
The discussion revolves around a 2004 VW Golf 5 experiencing a power steering issue, indicated by a red warning light and a connection error on the diagnostic computer. Initial troubleshooting included checking fuses and battery status, which were found to be functional. The power steering temporarily restored after driving 20 km but failed again upon restarting the engine. Suggestions for resolution included using VCDS for error checking, verifying power supply and CAN signals, and inspecting the steering angle sensor. A follow-up indicated that ultimately, the steering gear needed replacement.
