Which 24V IP67 power supply for LED 528 COB 15W/mb 4+5+4m instead of Mean Well 200W? 300Watt, but wh
nowickidamian 450 2
  • Recommending a 300 W 24 V IP67 supply
    #1 21876141
    nowickidamian
    I have LED lighting to install in the garden. I have purchased a 528 COB LED, which means I am assuming 15 W per mb. It has since turned out that the 200 W transformer from MEANWELL that I purchased will unfortunately not handle this for me (4, 5, 4 m sections). What trans power supply should I buy for this? What do you recommend, 300 W 24 V for such a length? IP67...
    I intend to keep the power supplies in airtight boxes outdoors, ballasted with 5 cm of soil.
    Would you recommend anything?
  • #2 21876206
    mohinder
    Help: 7
    Rate: 23
    How about the Mean Well HLG-320H-24? It should do the job.
  • #3 21876380
    nowickidamian
    Thanks. I was thinking something about the ELG model, the HLG is hard to find and expensive. And of the Chinese no name ones has anyone used anything?
