[Solved] Toshiba 32WA2063DG Vestel 17MB171 USB recovery upgrade_no_tvcertificate
MagneticPowerlink 855 8
  • #1 21896239
    MagneticPowerlink
    I need USB recovery firmware for:
    Model: Toshiba 32WA2063DG
    Main board: Vestel 17MB171
    S/N: 8792271 200224
    Date code: 2203
    Symptom: boot loop, Toshiba logo appears ~1 second, then restarts, LED alternates red/green
    TV reacts to USB stick (shows "UPGRADE ERROR" with empty file), so USB recovery method works.
    Need: upgrade_no_tvcertificate.pkg
    Thank you!
  • #2 21896337
    stacho57
    Help: 170
    Rate: 449
    Panel VES315WNGH-2D-N51?
  • #3 21896354
    yokoono51
    Help: 172
    Rate: 316
    Panel VES315WNGH-2D-N61 ?
  • #4 21896380
    MagneticPowerlink
    Sorry everyone, I'm a new member and I cannot see replies in the thread due to account restrictions. Please send me the information via Private Message. I am not ignoring you! Thank you for your patience.
  • #5 21896397
    Michał99
    Help: 140
    Rate: 345
    Panel: VES315WNGS-2D-N52 ?
  • #6 21896567
    MagneticPowerlink
    Panel confirmed: VES315WNGH-2D-N51
  • #7 21897026
    MagneticPowerlink
    >>21896337 Yes VES315WNGH-2D-N51
  • #8 21897082
    billobirillo
    Help: 338
    Rate: 798
    main 17MB171, panel VES315WNGH-2D-N51, cell HKC PT320AT02-2 V1.0
    software link
  • #9 21897733
    MagneticPowerlink
    @billobirillo Thank you, it worked
Discussion about recovering a Toshiba 32WA2063DG TV with Vestel 17MB171 main board that is stuck in a boot loop, showing the Toshiba logo briefly before restarting and alternating red/green LED. USB recovery is confirmed to work because the set reacts to an empty USB file with “UPGRADE ERROR”. The requested firmware is upgrade_no_tvcertificate.pkg, and the panel type was later confirmed as VES315WNGH-2D-N51.
