Toshiba 32WA3B63DG 17MB171 - where to download USB firmware? Full storage message
pjpcruz 519 5
  • #1 21918965
    pjpcruz
    Hello mates. I am new on this forum. I need firmware to fusb flash Toshiba 32WA3B63DG with Vestel 17MB171 BOARD.
    Thanks on advanced.
    What is the problem with TV now: dead, stuck on logo, rebooting, or only you need normal USB update firmware?
    Full storage message.
  • #2 21919078
    yokoono51
    Help: 168
    Rate: 308
    VES315WNGB-2D-N52 panel ??
    VES315WNGH-2D-N51 panel ??
  • Factory reset via service menu code 4725
    #3 21919160
    stacho57
    Help: 168
    Rate: 447
    https://www.elektroda.pl/rtvforum/topic4055210.html#21116593 As above, problem solved. After switching on the TV, I finally went to ‘Input’ on the remote and selected HDMI1, then pressed ‘Menu’ on the remote. A bottom menu with options appeared; I selected the ‘Advanced Options’ tile. Once in those options, I entered 4725 on the remote and the service menu appeared; then I performed a factory reset and it works. Perhaps you could try this method. You do so at your own risk. If not, write to yokoono51 and tell him what model you have. He’ll help.
  • #4 21919567
    pjpcruz
    >>21919078
    Hello thanks in advance.
    Mi panel is
    Added after 50 [seconds]:
    >>21919160
    I do not have the remote. Thanks anyway.
    I read somewhere that connecting a wired mouse could solve the problem by clicking in the upper right corner, but I wasn't successful.
  • #6 21921514
    pjpcruz
    >>21919951
    Worked like a charm. You are the best. Thank you.
