Looking for firmware Toshiba 32W1433DG (Vestel VES315WNDS-01)
dwaynec454 3426 5
  • #1 19903581
    dwaynec454
    Do you have firmware for Toshiba 32W1433DG (Vestel VES315WNDS-01)?
    Only the on/off lamp is blinking green or red depending on on or off tv. I don't have the remote.
    I tried a youtube method with some repair file but no success. The light on my usb drive is showing its red light when plugged in (no blinking. it usually blinks when files are being transferred).
    Aquario_blue
    Level 19  
    Help: 41
    Rate: 155
    If the mainboard is 17MB82S, use the attached software to recover
    • MB82_V.1.3.7.rar (9.16 MB) You must be logged in to download this attachment.
  • USB update not starting without remote or display
    #3 19914476
    dwaynec454
    I think so.
    How do u install it without RC, only physical buttons, no signs of image on the screen and no signs of sound.
    I put the pkg file in a USB Drive, only the file, no folders, nothing else. I unplug tv, insert usb, plug in tv, click on the physical power button.
    Light turns green, usb drive is red but not flashing just red light. In 5' tv turns off. I believe because of 5' of nothing happening, like some kind of power saving mode.
    Unplug the usb drive, click on the power button. And nothing, just the light turns green.
    But I don't think this file actually installed though.
    billobirillo
    Help: 338
    Rate: 798
    without remote control you can't restore the software
    how to restore
    insert the usb stick in the tv
    while holding down the ok button on the remote control, plug the power cord to AC mains
    continue to hold the ok button
    when the standby led starts to flash quickly, you can release the ok button and wait
    when the usb recovery is finished, tv will turn on by itself
  • #5 19915017
    dwaynec454
    thanks.
    does the replacement remote control work here or it MUST be a genuine remote control?
    billobirillo
    Help: 338
    Rate: 798
    it works also with a replacement remote control
