Hauppauge WinTV-HVR-935 PID_8360 – Error 10 on Windows 8.1 x64 – which driver should I use?
infinityhost 621 0
  • PID_8360 likely needs a different driver revision
    #1 21920118
    infinityhost
    Hi
    I’m having trouble with a Hauppauge WinTV-HVR-935 tuner on Windows 8.1 x64 and I’m looking for someone who has experience with the VID_2040&PID_8360 configuration.
    Hardware
    Hauppauge WinTV-HVR-935 (hybrid DVB-T/T2/C + analogue)
    Hardware ID:
    USB\VID_2040&PID_8360
    USB\VID_2040&PID_8360&REV_0100
    USB\VID_2040&PID_8360&MI_01
    Symptom
    After installing the driver, the device appears as:
    or
    Hauppauge USB Live 2 (depending on the installation attempt)
    but in Device Manager I get:
    > This device cannot start. (Code 10)
    What works
    the device is detected via USB
    USB Composite Device works
    the audio component is detected
    VID/PID is read correctly
    What doesn’t work
    The BDA/DVB part does not start
    The tuner is not available in TV applications
    Code 10 persists regardless of the driver version
    What I have already checked
    1. Hauppauge driver 39299:
    Driver10_6_0_119_39299-Win7-8-36075.exe
    2. WinTV v10:
    41041
    43323
    3. Manual configuration:
    hcw10bda.inf
    4. In the INF file, I found the entry:
    hcw10bda.DeviceDesc-B151 = "Hauppauge WinTV-HVR-935 (1115xx DVB-T/T2/C)"
    and the sections:
    POLARIS.B151
    POLARIS_XDS_Install.B151
    5. I forced the installation of HVR-935/B151 from the INF file.
    Result
    The driver installs correctly; the
    Hcw10bda.sys
    file is copied, but the device still ends up with Code 10.
    Additional information
    In the registry, the device is identified as:
    VID_2040&PID_8360
    I cannot see this PID in
    hcw10bda.inf
    – there are entries for B150/B151/C200 etc., but there is no direct entry for 8360.
    Questions
    1. Has anyone got the HVR-935 with PID_8360 working?
    2. Does VID_2040&PID_8360 require a different driver package than the standard 39299?
    3. Is this an OEM revision requiring different firmware?
    4. Does anyone have a newer
    hcw10bda.inf
    file that includes PID_8360?
    I would be grateful for any tips or a screenshot of a working INF entry for this device.
    Has this specific PID_8360 unit been tested on a different computer or a different operating system (e.g. Windows 10/7) and, if so, does the DVB/BDA component start up correctly there?
    On Windows 10, the same problem.
    What is the exact version of Windows 8.1 x64 (build/update level) and did you install the driver after disabling driver signature enforcement / on a clean system without any previous Hauppauge packages?
    Yes, I disabled driver signature enforcement; I used the Hauppauge cleaning tool, Windows 8.1 build 9600
