915MHz vs 2.4GHz: How to Choose the Right Frequency Band for Your Drone Receiver
chartloo 420 1
  • 915 MHz for long range, 2.4 GHz for low latency
    #1 21926398
    chartloo
    Introduction
    Choosing the right frequency band is the first critical decision when building a drone control link. 915 MHz (Sub-GHz) and 2.4 GHz have fundamentally different physical characteristics. There is no absolute "better" option - only what suits your flight scenario.
    Penetration: The Key to Avoiding Signal Loss
    915 MHz: With a wavelength of approximately 32 cm, it has strong diffraction capability, easily bypassing trees and building edges, maintaining link stability in complex terrain.
    2.4 GHz: With a wavelength of approximately 12.5 cm, it has weak diffraction capability. The signal path is essentially "line-of-sight," and signal strength drops sharply when obstacles are present.
    Anti-Interference Capability
    915 MHz: Fewer interference sources (mainly other LoRa devices). Combined with LoRa spread-spectrum technology, its anti-interference capability is extremely strong.
    2.4 GHz: The most congested ISM band, with dense interference from Wi-Fi, Bluetooth, and microwave ovens. Interference risk is higher in urban areas or event venues.
    Range and Latency
    915 MHz: Lower path loss, combined with LoRa's ultra-high sensitivity, gives it an unshakable advantage in long-range communication (several to tens of kilometers). However, the air data rate is relatively lower, and latency is slightly higher.
    2.4 GHz: Higher path loss, relatively limited range (though high-end modules can still reach 8 km). However, it supports high packet rates with extremely low latency, making it the best choice for FPV racing.
    Regulatory Restrictions (Critical)
    China: Drone remote control primarily uses 2.4 GHz. Using 915 MHz requires caution.
    United States: 915 MHz (FCC) is legally permitted and commonly used for long-range flights.
    Europe: 868 MHz is the primary band used.
    Conclusion: How to Choose?
    Long-range & complex terrain → 915 MHz. For example, agricultural drones operating in mountainous areas.
    FPV racing & low latency → 2.4 GHz. For example, racing drones.
    Ultimate solution: Dual-band redundancy. Use 2.4 GHz as the primary control link and 915 MHz as a long-range backup.
  • #2 21926441
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7875
    chartloo wrote:
    915 MHz
    In Poland, this frequency is used for other commercial purposes and is excluded from other uses. I suggest you familiarise yourself with local radio regulations.
