JVC LT-55N7125 EL.MT9602PRO-FG95 - bootloop, USB firmware for ST5501A panel
AvbFiber 51 1
  • Need USB firmware for ST5501A panel version
    #1 21929842
    AvbFiber
    Need USB firmware
    EL.MT9602PRO-
    FG95
    ST55 @ElektrodaBot
    What is the TV brand and full model number?
    JVC LT-55N7125
    Please provide panel model and photo/text from mainboard sticker, e.g. firmware/version/date printed on EL.MT9602PRO-FG95 board.
    Model TV: JVC LT-55N7125
    Mainboard: EL.MT9602PRO-FG95
    Panel: ST55
    Problem: Bootloop on logo, keys not working. Need USB firmware file: upgrade_image_no_tvcertificate.pkg
    I need firmware for ST5501A panel version only.
  • Need exact board and panel sticker details
    #2 21929847
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 359
    Rate: 945
    AvbFiber wrote:
    Need USB firmware
    EL.MT9602PRO-
    FG95
    ST55 @ElektrodaBot
    JVC LT-55N7125
    Please provide panel model and photo/text from mainboard sticker, e.g. firm...
    Initial assessment of available information
    For your set the identification is:
    ItemData
    TV brand / modelJVC LT-55N7125
    MainboardEL.MT9602PRO-FG95
    Required panel variantST5501A
    Required USB recovery filename
    FaultBootloop on JVC/logo, local keys not working
    Your request is technically valid, but the important point is: the firmware must match the ST5501A panel variant and the exact board/software sticker version. “ST55” alone is not enough for a safe match.
    Direct answer
    I cannot confirm a publicly available, verified JVC LT-55N7125 / EL.MT9602PRO-FG95 / ST5501A USB package from official JVC sources. Current JVC TV support information states that downloadable TV firmware files are not provided to end users; TV firmware updates are normally OTA only. (esi-support.zendesk.com)
    Therefore, do not flash a random
    EL.MT9602PRO-FG95
    package unless it is explicitly confirmed for:
    - JVC LT-55N7125
    - EL.MT9602PRO-FG95
    - ST5501A panel
    - same or compatible board sticker/software version
    A wrong package may boot the TV but give black screen, inverted image, wrong colours, no backlight, wrong V-by-One/LVDS mapping, or may require full eMMC reprogramming.
    What is still needed before a safe firmware match
    Please provide the exact text or clear photo from:
    1. Mainboard sticker
    - Any line containing
    SW
    VER
    DATE
    FG95
    MT9602
    , barcode, production code.
    2. Panel label
    - Not only
    ST55
    , but the full panel code, for example:
    ST5501A...
    ST5501A04
    ST5501Axx
    - or equivalent manufacturer code.
    3. Any second small sticker on the board
    - Many EL/MTK boards have a separate sticker with the factory firmware build or panel configuration.
    Without this, the request remains ambiguous even if the mainboard number is correct.
    Practical USB recovery procedure, once the correct file is obtained
    Use only the verified ST5501A package.
    1. Use a small USB stick, preferably USB 2.0, 4–16 GB.
    2. Format as:
    - FAT32
    - MBR
    - single partition
    3. Copy only this file to the root directory:
    Code: text
    4. Disconnect TV from AC power.
    5. Insert USB stick into the main USB/service port.
    6. Press and hold the TV local Power key. If no reaction, later also try VOL- or VOL+ depending on key board behaviour.
    7. While holding the key, connect AC power.
    8. Keep holding for about 10–20 seconds.
    9. If the bootloader accepts the package, LED blinking or an update screen/progress bar should appear.
    10. Do not interrupt power during update.
    If the USB update does not start
    If the TV ignores the USB file, possible causes are:
    - wrong firmware package,
    - wrong file name,
    - USB stick not detected by bootloader,
    - damaged bootloader,
    - corrupted or failing eMMC,
    - package signature/certificate mismatch.
    If the update appears to complete but the TV returns to the same logo bootloop, suspect eMMC failure. On these Android/Google TV boards this is common. In that case a USB package will not solve the problem; the repair requires:
    - reading/replacing the eMMC,
    - programming a full dump from a compatible donor board,
    - preserving/calibrating panel data, MAC/Wi-Fi data, certificates where possible.
    Important correction
    This is an MT9602/MediaTek-type Android/Google TV platform, so avoid mixing it with unrelated Vestel, MStar or generic JVC firmware. JVC support pages may list firmware for other JVC product categories such as projectors, car audio or cameras, but that does not mean a valid USB TV firmware exists for this chassis. (support.jvc.com)
    Recommended next step
    Post the following here:
    Code: text
    With the full mainboard sticker and full panel label, it will be possible to check whether another member has the exact ST5501A USB recovery package or whether you need a full eMMC dump instead.
