Hitachi 43HAE4252 17MB171 - storage full, HDMI input restarts TV, need firmware
kbtpce 132 2
  • Need firmware and service menu details for full storage issue
    #1 21934691
    kbtpce
    Hi!
    I have a Hitachi 43HAE4252 TV.
    The problem is cache is full. When the TV is turned on, it only writes this message: the space is full.
    If I want to choose input HDMI (for example, connect to my PC), the TV restarts.
    So I need a SW for this TV.
    28576635
    10128610
    MB: 17mb171
    Can you help me?
    Can you write all information from the TV back label and from menu/service menu, especially current SW/firmware version, panel code, serial number, and Vestel profile number if you see it?
    Yes.
    What did you already try: factory reset, clear cache/data, uninstall apps, USB firmware update, or service menu reset? Does the TV stay on if you do not choose HDMI?
    Yes, TV is turned on if I don't choose HDMI, but it does not work.
    Can't factory reset.
    Can't service menu because the TV only writes not enough space.
  • #2 21934738
    billobirillo
    Help: 336
    Rate: 783
    main 17MB171, panel VES430UNDH-N2-N45, tcon NEMUS FHD HKC PT430CT03-14
    here is the software link
    the software is from a Toshiba, but it fits perfectly on your Hitachi
    it works, but the startup logo will change
  • #3 21934756
    kbtpce
    >>21934738
    Now a TV is woking correctly.
    Thanks for your collaboration.
