[Solved] Where to download Philips 32PFL7404H/12 firmware 000.026.078.000 or newer?
dricardo01 396 6
  • Seeking newer compatible firmware for Philips 32PFL7404H/12
    #1 21943677
    dricardo01
    Hello!
    I need help finding the firmware update file for the Philips TV, version 000.026.078.000.
    TV specifications:
    Model: 32PFL7404H/12;
    Chassis: Q548.1E LA;
    Serial No.: VN3B 0951 098346.
    I’d really appreciate it if you could help me! Thank you.
    AI: Do you need exactly firmware version 000.026.078.000, or would the latest compatible firmware for the Philips 32PFL7404H/12 also be acceptable?
    Any newer firmware that is compatible and fully functional on the TV I own.
    AI: What firmware version is currently installed on the TV, and why do you need this update file - normal update, repair/recovery, downgrade, or fixing a specific problem?
    I have 000.026.071.000 installed. It was just a normal update to keep TV working properly.
  • #3 21944304
    dricardo01
    Hello! Yes! But if you click on download button it will prompt you the download URL, but it does not work because Philips shut down the servers where they had old firmware packages. Do you now where I can get it?
  • #4 21944316
    lisek
    Service technician RTV
    Help: 6354
    Rate: 6885
    Search the (archived) Philips FW collection Link
    billobirillo
    Help: 338
    Rate: 799
    here is the software for chassis Q548.1E LA version 000.026.078.000
    • Q548.1ELA 000.026.078.000.zip (42.7 MB) You must be logged in to download this attachment.
  • #7 21944330
    dricardo01
    It worked! Thank you so much!
The discussion concerns locating a firmware update for a Philips TV, specifically firmware version 000.026.078.000 or any newer compatible release for the 32PFL7404H/12. The TV uses chassis Q548.1E LA and currently runs firmware 000.026.071.000. The requested update is for a normal maintenance update to keep the television operating properly.
