[Solved] What do the names of the cables mean? GND, ACC, LIGHT, BATTERY, REMOTE.
siwy80-80 120622 3
  • #1 2714706
    siwy80-80
    what do the names of the cables mean and which to connect to the power supply and which to the ground because I have a big problem with it, I do not give the names of the speaker cables because I know which ones but I do not know what the others mean.
    Here are the cables
    GND
    ACC
    LIGHT
    BATTERY
    REMOTE
    The names of these cables are on the radio a bit of a historic Denon DCR-710r
    Mleczyk89
    Help: 291
    Rate: 266
    GND mass of course
    ACC turning on the radio ignition switch voltage after turning the ignition switch (if you prefer to connect it to the battery, you will be able to listen to the radio without keys.
    BATTERIES radio memory backup to + 12V battery
    REMOTE control the extended antenna or switching the amplifier on
    LIGHt it seems to me that it is something like in blauppoints that by adjusting the dashboard lighting, you can adjust the brightness of the radio, but only in some cars
  • #3 2714766
    ostry17
    Help: 6
    Rate: 20
    gnd - mass
    acc - + 12V power supply
    Light - illumination of the dashboard
    battery - battery backup
    remote - remote control, joystick
    I think so, but I could have made a mistake, because I'm irritable (2: 0 for Ecuador)
    Greetings
  • #4 20849111
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Resolved = closing.
