Testing Converter Functionality: DIY Methods & Evaluating Parameters, Analog Tuner Inspection
Kuba19 66856 5
  • #1 2855371
    Kuba19
    Rate: 18
    the question is how to check the converter whether it is functional (can it be done at home without any special equipment) or, for example, by comparing some parameters, it is possible to find out if it is not burnt, and the second question is whether you can check the analog tuner somehow. e.g. by buying it on the stock exchange (so as not to get on the roller and buy a broken one
    Thank you in advance for your help
    Cuba
  • #2 2855549
    KaW
    Help: 170
    Rate: 306
    never buy equipment without demonstration - the lack of demonstration results in a price reduction of 50% ... but who needs a pile of scrap metal ... even for 5 zlotys.
  • #3 2855895
    Kuba19
    Rate: 18
    Okay, what about the converter, I have two and I do not know how to check them, and I do not have a tuner from everybody and I do not want to buy a tuner as converters do not work
    Greetings
  • #4 2855923
  • #5 2857268
    KaW
    Help: 170
    Rate: 306
    CONVERTERS are probably not needed anymore - after all new equipment - full bandwidth -
    why buy a tuner with an old band-
    one out of 10/20 / it is possible to tune well - converters bring noise -
    pity such pretty ears for these noises ..
    I'm sorry -it's about SAT -MY WTRETY ARE WITHOUT ANY AGENCY-
    I'm sorry Cuba.
    Added after 11 [minutes]:
    You must have an antenna - a dish and some simplest reception. sat- used
    analog ones cost PLN 20 - the risk is always there, but if it is a set, it's worth checking.
    This is a lamentation - because the progress is very big - and those converters that were good yesterday - today are invalid - just because of noise and other properties.
    I would not insist on satellite TV - it would be interesting
    direct to receive digital terrestrial TV - on one channel 10 stations - each without reflections - satellites are above us 100km above the ground ...
    If you still have your roof, you can look for something in the sky -
    from the balcony it's a bit worse .....
  • #6 3569866
    Kuba19
    Rate: 18
    Thanks for your help, if there is anything else wrong, I'll talk to you
    thx again
