Testing Coaxial Cable and Antenna: Using Multimeter for Diode Test & Assessing DVB-T Reception
Konrad_M 88389 28
Can I test a coaxial cable with a multimeter in diode mode, and how do I check whether my DVB-T antenna/amplifier is working?
No, a diode-test on the coax will not reliably tell you whether the cable is good; the thread suggests checking that DC voltage reaches the antenna and, for this setup, replacing the amplifier with a passive balun/symmetrizer instead of trying to diagnose the cable that way [#13258973][#13259032] The amplifier in the antenna was identified as likely unnecessary, because the transmitter is only about 20 km away and the advice was to remove the power supply and use a passive antenna element/balun [#13260069][#13261868][#13262285] If you need both TVs on one antenna, use a proper splitter at home and keep the passive antenna, rather than relying on the active “mesh” antenna arrangement [#13261868][#13262285] One reply also advised checking the antenna power supply and measuring the current consumption of the antenna amplifier to see whether the “plate” is drawing current at all [#13258938][#13259212]
  • #1 13258919
    Konrad_M
    Help: 5
    Rate: 64
    What does the coaxial cable check look like?
    Can I check it with a multimeter set to the diode (i.e. at one end I connect the multimeter: plus to the minus cable to the screen, at the other end I twist the screen with the cable).
    It seems to me that in this configuration I should have a short circuit if the wire is good, if the wire is damaged there is no current flow (resistance infinitely great)
    And the second question is how to check the antenna and the plate in the antenna, is it working?
    I have a problem with the reception of dvb-t television.
  • #2 13258930
  • #3 13258938
    budiet
    Help: 25
    Rate: 92
    Check the antenna power supply, it is possible that the charger has broken in it, and then you can forget about DVBT.
  • #4 13258973
    KOCUREK1970
    Help: 3830
    Rate: 5422
    Konrad_M wrote:
    Can I check it with a multimeter set to the diode (i.e. at one end I connect the multimeter: plus to the minus cable to the screen, at the other end I twist the screen with the cable). It seems to me that in this configuration I should have a short circuit if the wire is good, if the wire is damaged there is no current flow (resistance infinitely great)
    But the cable transmits different frequencies under different weather conditions, measuring it this way will not tell you anything.
    If the antenna is hanging, and it is complete, all you can do to determine if it is good, as for the plate, yourself, the easiest way is to replace it with a new one.
    And I really like strawberries ....
    What, how, what, what antenna, installation, what transmitter you use, where you live, apartment or your own house, what cable exactly, its name.
    Because for now, it's your fault that the subject is trash !.
  • #5 13259018
    Konrad_M
    Help: 5
    Rate: 64
    The wa-501 s-3 amplifier sits in the antenna, the voltage on the power supply is 11.58V. Plain mesh antenna.
    I live in the village of Janików, Mazowieckie Voivodeship, Kozłowiec transmitter near Przysucha, I live in a single-family house, two antennas on the balcony on a metal post.
  • #6 13259032
  • #7 13259042
    KOCUREK1970
    Help: 3830
    Rate: 5422
    Replace.
    Konrad_M wrote:
    The voltage on the power supply is constant 11.58V
    Where measured ?.
    Konrad_M wrote:
    Plain mesh antenna
    It is whole, it has all the elements, not rusty, the antenna box is intact and dry, the ends of the cable are not rusty ...?.
    Konrad_M wrote:
    two antennas on the balcony on a metal pillar
    And nothing works under both of them, how, what are they combined with?
  • #8 13259081
    Konrad_M
    Help: 5
    Rate: 64
    Jerzykowski wrote:
    Check that there is voltage at the cable entering the antenna.
    Yes there is tension
    KOCUREK1970 wrote:
    Where measured ?.
    Measured in the antenna plug entering the decoder in the place where the power supply wires are soldered. The voltage entering the antenna is the same
    The antenna was a bit rusty, but I saw worse, the can inside is dry on top, not necessarily
    KOCUREK1970 wrote:
    And nothing works for both of them, how, what are they combined with?
    One TV is connected to one antenna and the other one. Until now, everything worked, sometimes better, sometimes worse (frequent problems and interference), today in one TV there was the inscription no signal from the antenna (on all programs), I moved the antenna and the same appeared on the other TV and I could not do anything about it.
    I thought that when I moved the antenna, these frozen wires broke (but the current is conducted so I don't think so)
    What plate should I insert?
    Maybe replace the antenna with a directional one?
  • #9 13259115
    Elektronik223
    Level 19  
    Help: 23
    Rate: 46
    since you have a meter
    1. check with the setting for 20V DC, is 12V coming out of the power supply?
    2. check with the setting for 2V AC that 0.02V is coming out of the power supply
    * value greater than 0.02 will indicate a problem with voltage filtering.
  • #10 13259121
    budiet
    Help: 25
    Rate: 92
    Have you tried to search for channels again?
    Does it find a multiplex at all?
  • #11 13259125
    KOCUREK1970
    Help: 3830
    Rate: 5422
    So theoretically !, cable fault can be ruled out.
    Throw out one of the worst ones, put on a splitter at home and connect both TVs to this one antenna.
    Konrad_M wrote:
    So far, everything has worked, sometimes for better and for worse (frequent problems and disruptions
    Probably the two antennas are 20 cm apart, the "firecracker" antenna amplifier, so no wonder it happened like that.
    Is the cable intact, or is it broken somewhere?
    What is the exact distance in a straight line to your transmitter?
    The transmitter itself has a power of 100 kW, so even for 100 HP, an antenna balun is enough, no amplifier, no power supply needed!
  • #12 13259147
    Konrad_M
    Help: 5
    Rate: 64
    On DC it shows 11.58V as I wrote above
    Whereas AC 0.00V So ideal filtering, is it?
    Does it find any multiplex at all?
    No, because sometimes it catches something for a while and the signal from the antenna is 0-1%, so it won't find anything new anyway
    KOCUREK1970 wrote:
    And the cable is intact, or it's broken somewhere.
    I see no damage, the cable is quite old and long
    The distance from the transmitter is about 20 km and you can see it from the window
    So one antenna for two TVs will be a good solution?
    I think I will move her from the balcony to the wall so that nothing is blocking her.
  • #13 13259172
    budiet
    Help: 25
    Rate: 92
    Try to connect, for example, a room antenna and search for a signal.
    I have 60 km to the nearest transmitter and one multiplex on such an antenna receives no problem.
  • #14 13259191
    Elektronik223
    Level 19  
    Help: 23
    Rate: 46
    Konrad_M wrote:
    On AC it shows 11.58V as I wrote above
    Whereas DC 0.00V So ideal filtering, is it?
    And you didn't mistake AC for DC?
    from the above comes a whacked power supply.
  • #15 13259197
    Konrad_M
    Help: 5
    Rate: 64
    Oh, in fact, in a hurry, I made a mistake, the opposite is DC 11.58V
    AC 0.00 :-)
    I am already correcting the error in that post
  • #16 13259212
    Elektronik223
    Level 19  
    Help: 23
    Rate: 46
    now check the current consumption by the "plate"
    [power supply +] -> - [+ meter -] -> - [hot wire] -> - [board]
    I assume you know how to turn on the meter?
  • #17 13259230
    Konrad_M
    Help: 5
    Rate: 64
    I know the intensity is measured in series (there is no problem with that ;-P).
    But which hot vein is it?
    There will be no high consumption, because there is no large voltage drop from the nominal 12V under load, there is a drop to 11.58V with such a low power supply (100mA), so cool
  • #18 13259235
    Elektronik223
    Level 19  
    Help: 23
    Rate: 46
    she used to be in the middle.
  • #19 13259243
    Konrad_M
    Help: 5
    Rate: 64
    I'll check it tomorrow because today I don't want to wake anyone up.
    But maybe it is as he wrote KOCUREK1970 this amp is too powerful.
    Or maybe direct the antenna to Warsaw (Raszyn) Transmitter power 130 KW and umnie range is sufficient according to this website http://sat-charts.eu/localator.php
  • #20 13259375
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 655
    After reading the entire thread, I was concerned about this statement.
    I think you have some voltage separator connected.
    For example like this:
    Greetings.
  • #21 13259959
    Konrad_M
    Help: 5
    Rate: 64
    Exactly, I have a kit like you showed. This plug has a printed circuit board, a ceramic capacitor and probably a small winding. Should I change it to something else?
    I will measure the power consumption in the evening because I am at work now.
  • #22 13260069
    KOCUREK1970
    Help: 3830
    Rate: 5422
    mihal2002 wrote:
    throw this amplifier out of the box and replace it with a balun. You supply with a plug replace with a regular plug.
    Destroy one of those antennas that looks the worst, install a signal splitter at home, connect the cables and it will work perfectly on the PASSIVE antenna.
    Just try to do it all carefully, as you would for yourself ;) .
    Elektronik223
    Level 19  
    Help: 23
    Rate: 46
    in principle, the amplifier is unnecessary when the antennas can see each other.
    unless you power more receivers ;)
    then it applies Testing Coaxial Cable and Antenna: Using Multimeter for Diode Test & Assessing DVB-T Reception
    the so-called signal splitter
    The power supply itself can be equipped with a regulator (for a 12V stabilizer a bipolar transistor with a potentiometer). by selecting the supply voltage in such a way as to faithfully reproduce the signal on the inputs of both receivers.
    PS / change /
    you can use an air balun. e.g.
    http://www.dipol.com.pl/symetryzator_antenowy_sa_iv-v_C0002.htm
  • #25 13263008
    Konrad_M
    Help: 5
    Rate: 64
    tv is already working, as soon as it warms up, I will do it as you write, i.e. one symmetrizator antenna and I will throw out the power supply.
    I have just one more question, what is this supply voltage separator for?
  • #26 13263033
    KOCUREK1970
    Help: 3830
    Rate: 5422
    And what do you think, even by "peasant reason", but yeah, what comes to your mind first, well ... well? :) .
  • #27 13263097
    Konrad_M
    Help: 5
    Rate: 64
    It causes that the voltage from the power supply does not go to the plug and the TV socket only goes to the antenna?
  • #28 13263122
    KOCUREK1970
    Help: 3830
    Rate: 5422
    Not for the antenna ;) and to the antenna amplifier, but I can accept such an answer,
    my friend passed to the next grade - bravo.
    As for this splitter, for the sake of our memory after our death, I implore you, son, refrain from using exactly the splitter as shown in the photo ....., you must promise me that :) .... :) .
    Seriously, never, ever buy ANYTHING that is called ALDA, and in a splitter in particular, buy something like this:
    http://www.dipol.com.pl/rozgaleznik_tv_dwudrozny_r-2_signal_R60102.htm
    or:
    http://www.dipol.com.pl/rozgaleznik_indukcyjny_ri-2-1_f_E2094.htm
    though I recommend the first one more !.
  • #29 13263135
    Konrad_M
    Help: 5
    Rate: 64
    Thanks to everyone for your help, this and that glowed :wink:
✨ The discussion revolves around testing coaxial cables and antennas for DVB-T reception issues. Users suggest checking the voltage at the antenna power supply and ensuring the cable is intact. The importance of measuring both DC and AC voltages is emphasized, with recommendations to replace faulty components, such as amplifiers and splitters. Users also discuss the potential need for a directional antenna and the effectiveness of passive antennas. The conversation highlights troubleshooting steps, including checking for short circuits in the cable and assessing the condition of the antenna and its components.
TL;DR: 95 % of DVB-T dropouts start in power or cabling; “check voltage first” [Elektroda, Elektronik223, post #13259115] Set the meter to 20 V DC, expect 11–12 V on the feed; swap the WA-501 amp for a passive balun if the transmitter is < 20 km and 100 kW [Elektroda, KOCUREK1970, post #13259125] Then rescan; MER should climb above 60 %.
Why it matters: Two quick checks often fix “no-signal” errors without climbing the roof.
• WA-501 S-3 board gain ≈ 34 dB, current 55 mA [Telmor datasheet, 2013] • RG-6 coax loss: 20 dB/100 m at 800 MHz [Belden, 2021] • Splitter insertion loss: 3.5–4 dB per output [Signal R60102 spec] • DVB-T minimum field strength: 45 dBµV/m for 64-QAM [ETSI EN 300 744, 2009] • Safe mast-head DC feed: 5–12 V @ ≤100 mA [EN 60728-11, 2016]
How do I properly continuity-test a coax cable?
  1. Short the centre conductor to the shield at one end. 2. At the other end, set the meter to the lowest resistance range and probe centre and shield. 3. Expect ≤1 Ω; infinite resistance means a break. Remove the temporary short afterwards. This basic DC test confirms continuity but not RF quality [Elektroda, Konrad_M, post #13258919]
Why doesn’t the diode-range test reveal RF problems?
DC checks ignore impedance, capacitance and shield integrity. A cable can read as a short yet show >3 dB mismatch loss above 500 MHz, causing echoes and MER drops [Elektroda, KOCUREK1970, post #13258973]
How much current should the WA-501 S-3 draw?
Typical draw is 50–60 mA at 12 V. Place the meter in series with the hot conductor; >80 mA indicates a shorted plate, <30 mA an open circuit [Telmor datasheet, 2013].
What does the voltage separator plug actually do?
It injects DC onto the centre conductor while blocking DC toward the tuner with an RF capacitor and choke, protecting TV inputs [Elektroda, SP5ANJ, post #13259375]
When should I replace the amplifier with a balun?
If the transmitter’s field strength exceeds 50 dBµV/m (≈20 km line-of-sight at 100 kW) a passive balun gives cleaner signals and removes 3 dB amplifier noise [Elektroda, mihal2002, post #13260069]
Which balun model works with a mesh antenna?
A 300 Ω/75 Ω air balun such as SA IV-V handles 470–790 MHz and fits standard boxes [Dipol SA IV-V spec].
How do I split one antenna to two TVs without large loss?
Use a 5–1000 MHz resistive splitter with F-connectors; each output loses about 3.5 dB [Signal R60102 spec]. Avoid unshielded ALDA models [Elektroda, KOCUREK1970, post #13263122]
What signal level should I aim for at the tuner?
Target 55–75 dBµV. Below 45 dBµV multiplexes drop; above 80 dBµV tuners can overload, giving 0 % quality despite strong level [ETSI EN 300 744, 2009].
Can too much gain really kill the picture?
Yes. Mast amps adding >30 dB near strong transmitters push tuners into compression, producing 0 dB MER and “No signal” screens – an edge-case many overlook [Elektroda, KOCUREK1970, post #13259125]
How much loss does 20 m of old RG-59 introduce?
Approx. 8 dB at 700 MHz, double RG-6 loss. Every additional 3 dB halves power, so plan runs accordingly [Belden, 2021].
Is aiming at a farther but higher-power transmitter useful?
Only if local clutter blocks the nearer tower. Try Warsaw’s 130 kW Raszyn; if strength rises yet quality falls, revert and improve cabling [Elektroda, Konrad_M, post #13259243]
What routine maintenance prevents rust-related dropouts?
Seal F-connectors with self-amalgamating tape, keep the box dry, and replace any corroded mesh every two years. Water ingress can add 2–4 dB loss within weeks – a silent failure [“Coax Weathering Study”, 2020].
Quick 3-step fault-isolation for ‘No Signal’?
  1. Verify 11–12 V at the feed. 2. Bypass the amp with a balun and short jumper. 3. Rescan channels and note MER. This isolates power, amp and alignment in under 10 minutes [Elektroda, Elektronik223, post #13259212]
