Why Does DC Lose Power Over Distance, and Why Is AC Used for High Power and 400Hz Systems?
387 8
  • #1 21665984
    umer majid
  • Clarifies AC use, 400 Hz, and inverter basics
    #2 21665985
    Earl Albin
  • Clarifying DC transmission, AC preference, and 400 Hz effects
    #3 21665986
    umer majid
  • AC used for transmission because transformers step voltage up
    #4 21665987
    Steve Lawson
  • #5 21665988
    M Baker
  • Submerged dc cable may avoid transformer losses
    #7 21665990
    Patrick Walsh
  • #8 21665991
    Steve Lawson
  • #9 21665992
    Patrick Walsh
DC power transmission does not inherently lose more power over long distances than AC; the key advantage of AC lies in its ability to be easily transformed to higher voltages using transformers. Transmitting power at higher voltages reduces current, thereby minimizing resistive losses (I²R) in transmission lines. This is why AC is preferred for high power transmission and devices. The choice of AC frequency depends on application: 50/60 Hz is standard for general power distribution, while 400 Hz is favored in aerospace and other weight/size-sensitive systems due to reduced transformer and motor size, despite increased audio noise and filtering challenges. DC power sources such as batteries (e.g., 28V or 26V) can produce higher voltage AC outputs through inverters, which are complex electronic circuits that convert DC to AC. Historical and modern examples include high-voltage DC transmission systems, such as those using Siemens technology and the Sylmar Converter Station, which converts high-voltage DC to AC using large mercury arc rectifiers. The fundamental reason AC remains dominant is the ease of voltage transformation and efficient long-distance transmission, although advances in DC technology are emerging.
