Difference Between AC (Alternating Current) and DC (Direct Current) for Paper Writing
ziomek2 51699 3
  • #1 3310892
    ziomek2
    What is the difference between AC and AC? Please, give me a specific answer because I have to write a paper about it.
    thanks in advance for your reply
  • #2 3310923
  • #4 3310940
    DARREK
    Help: 17
    Rate: 28
    Alternating current (AC) is a characteristic case of a periodically alternating current in which instantaneous values change in a repetitive, periodic manner. The instantaneous values of the alternating current intensity take alternately positive and negative values (hence the name alternating). Most often, it is desirable for the full-time mean value (ie constant component) to be zero.
    Current and voltage with a sinusoidal waveform are relatively of the greatest practical importance. Therefore, in technical jargon, the term alternating current often simply means sinusoidal current. If the noise or non-linearity causes a deformation of a sinusoidal shape, then such a non-sinusoidal waveform is called a distorted waveform.
    Alternating current is an electric current whose intensity value is a function of time. Basically, alternating current is a term that can be used to describe any type of current - even direct current is a function of time.
    Nevertheless, it is generally accepted that the instantaneous values of alternating current are subject to change. Depending on the nature of these changes, the following types of current can be distinguished:
    * periodically alternating current
    o ripple current
    o alternating current
    * non-periodic current
    All the above items, except the last one, are special cases of alternating current and they have a special meaning in electrical engineering and electronics. The non-periodic alternating current can represent a current of any variation with time (the black curve in the figure), or a current that changes according to a specific mathematical function or mathematical phenomenon. For example, when a power line is struck by a lightning bolt, a shock wave of a certain shape is created that occurs once, so there is no periodicity.
    PS Google is your friend
    • Difference Between AC (Alternating Current) and DC (Direct Current) for Paper Writing Zmienność_prądu.png (12.25 KB) You must be logged in to download this attachment.
    • Difference Between AC (Alternating Current) and DC (Direct Current) for Paper Writing Przebieg_przemienny.png (15.46 KB) You must be logged in to download this attachment.
