What do the terms AC and DC mean?
stabilizator 110343 23
  • The terms AC and DC refer to electric current. Indirectly, also tensions.
    DC - direct current - means direct current. In theory, it is a power supply whose parameters are constant over time. Most often we say that about all sources that give a constant voltage. However, no one can guarantee that the output voltage, e.g. from the power supply, will be e.g. 12.13454V all the time. It can fluctuate or slightly change under the influence of the current consumption and the ambient temperature. In addition, the voltage coming from the power supply may have some ripples resulting from imperfect filtration (e.g. unstabilized power supply and also impulse power supply). It may turn out that the supply voltage is variable (to an extent not important from the point of view of the receiver).
    Therefore, the "utility" definition of direct current is a bit broader - it is required not to change its direction. That is why we can name the voltage at the terminals of e.g. a battery, which is first 14.4V, and then slowly decreases due to discharge. Direct current can also be called a power supply from a DC generator driven by a wind turbine, the output voltage of which varies, for example, from 4V to 11V, depending on the current strength of the wind. A photovoltaic panel can be a similar DC source.
    AC - alternating current - means alternating current, and more often periodic alternating current, it is one whose value changes in an intended and deterministic manner, i.e. sinusoidal. However, two subgroups can be distinguished here:
    - alternating current, i.e. one whose value changes but does not change its direction (does not cross zero)
    - alternating current, i.e. a variable whose value changes the sign (passes through zero)
    In the Anglo-Saxon literature, the term AC is used to denote the latter type of current, i.e. alternating current. Alternating current can be called all non-zero waveforms that contain ripple or other distortions - that is, what I classified above as DC, because we look at what these waveforms should be intended for. It is difficult to set an unambiguous border, therefore a certain, customary classification has been adopted here. Mains supply 230V 50Hz belongs to AC. The AC supply allows the operation of e.g. induction motors or transformers.
    "Author: Michał Kurzela / Futrzaczek"
    "Correction: stabilizer"
    stabilizator
    Editor
    stabilizator wrote 142 posts with rating 361. Been with us since 2020 year.
  • #2 18512088
  • #3 18512137
    Freddy
    Help: 1394
    Rate: 2821
    Adamcyn wrote:
    Lots of inaccuracies.
    Then please show these inaccuracies. ;)
  • #4 18512199
    398216 Usunięty
    Help: 3925
    Rate: 9448
    The text (in my opinion) translated with a translator with a slight Author's correction - instead of writing (or rather pasting the translation) it would be better to paste the link to the original.
  • #5 18512306
  • #6 18512504
    Freddy
    Help: 1394
    Rate: 2821
    The second is:
    - AC, i.e. alternating current means (ignoring that it was alternate current) alternating current. :)
    the third is:
    - alternating current is current periodically changing in which the instantaneous values have alternating positive and negative values.
  • #7 18512627
    stabilizator
    Editor
    Rate: 361
    Delving into seemingly simple issues often leads to a surprising discussion.
    The topics in the guide section are open and this gives the opportunity to jointly expand the content by people with practical experience and knowledge in a given topic.
  • #8 18512682
  • #9 18512857
    stabilizator
    Editor
    Rate: 361
    I think that there is no permission or prohibition here, this is an open topic and everyone can express their opinion on the forum, but from my point of view it is worth sticking to the original topic as much as possible.
    OK, my opinion is that it is worth discussing AC / DC because, depending on the specifications of the circuit, these terms may have slightly different meanings. However, I would like to avoid overshooting the topic and losing the main plot.
    So in turn:
    Adamcyn wrote:
    I think so too.
    E.g.:
    stabilizator wrote:
    AC - alternating current - means alternating current.
    It's the one that value changes intentionally and deterministically, that is, for example, sinusoidal.
    So we have some assumptions about the system, e.g. the inverter output where it will be at the AC output, and it is a deterministic change, e.g. a 50Hz sine with a specific RMS voltage.
    Freddy wrote:
    The second is:
    the third is:
    Alternating current is alternating current, but not all alternating current has to be alternating, so alternating current is a more general term.
    Adamcyn wrote:
    So, Dear Editor, we have permission for further comments.
    14.4 V could be the voltage on the acid battery during charging.
    The voltage of such a fully charged battery is approximately 12.7 volts.
    This voltage of 14.4V and the battery is just an example, there is no indication whether it is a lead-acid battery, it could be e.g. a battery consisting of 4 Li-ion cells with a current voltage of 3.6V. However, what you mention, i.e. the voltage in the system with a battery charged to 14.4V, and then the voltage drop to 12.7V, is also an example of an alternating waveform, but in most cases we will define the power supply of such a system as DC - direct voltage, not variable voltage (although in reality changes over time).
  • #10 18513524
    Freddy
    Help: 1394
    Rate: 2821
    You are wrong - alternating current is current periodically changeable.
    Definition from a high school textbook
    Alternating Current (AC) is a special type of periodically alternating current in which the instantaneous values have alternating positive and negative values.
    They change with a certain frequency and periodically. A desired parameter is also a constant component with a value of zero. Most often it occurs in the form of a sinusoidal current.
  • #11 18513985
  • #12 18514198
  • #13 18514328
  • #14 18514446
    stabilizator
    Editor
    Rate: 361
    Adamcyn wrote:
    Of course, you are right.
    stabilizator wrote:
    AC - alternating current - means alternating current. It's one whose value changes intentionally and deterministically
    According to definition:
    Alternating current - electric current for which the value of the intensity changes over time by any means .
    So not deterministically - quite the opposite.
    Where did you get this term to describe the current?
    In fact, an alternate will fit better here, I change, thanks.
  • #15 18636359
    CYRUS2
    Help: 1241
    Rate: 3535
    AC is an idiomatic phrase meaning both alternating voltage and current.
    It is an accepted international term.
    Voltage 230V AC.
    Current 10A AC
    Some used it thoughtlessly and it came out of stupidity.
    / voltage of 50V alternating current /
    Standard 60364-4-41 2000:
    As if someone wrote, I ate a "hot dog".
    They improved in the new standard.
    DC - Direct current is also an idiomatic phrase.
  • #16 18637591
    Freddy
    Help: 1394
    Rate: 2821
    Alternating current, abbreviation AC, flow of electric charge that periodically reverses. It starts, say, from zero, grows to a maximum, decreases to zero, reverses, reaches a maximum in the opposite direction, returns again to the original value, and repeats this cycle indefinitely. The interval of time between the attainment of a definite value on two successive cycles is called the period, the number of cycles or periods per second is the frequency, and the maximum value in either direction is the amplitude of the alternating current.
    Direct current, abbreviation DC, flow of electric charge that does not change direction. Direct current is produced by batteries, fuel cells, rectifiers, and generators with commutators.
    Źródło Encyclopedia Britanica
  • #17 18638417
    CYRUS2
    Help: 1241
    Rate: 3535
    Freddy wrote:
    Alternating current, abbreviation AC, flow of electric charge that periodically reverses ......
    Source Encyclopedia Britanica
    Texts in another language are not translated.
    Translations are done.
    Lest it turn out that I ate a "hot dog".
  • #18 18906682
    Rafikusa
    Help: 27
    Rate: 66
    Adamcyn wrote:
    atom1477 wrote:
    English AC is alternating current only and exclusively.
    Wechselspannung in German - also.
    But that is already a term for tension.
    The term Wechselstrom is used on a daily basis.
  • #19 18906697
  • #20 18909013
  • #21 18909080
  • #22 18909089
  • #23 18909158
  • #24 19762003
    ken-wawa
    Rate: 141
    How do you say alternating current in English? Variable current? What is the term used?
The discussion revolves around the definitions and characteristics of AC (Alternating Current) and DC (Direct Current). DC is described as a constant voltage source, although real-world applications may show slight fluctuations due to various factors. AC is defined as a current that periodically changes, with alternating positive and negative values. Participants debate the accuracy of definitions, the implications of these terms in practical applications, and the importance of context in understanding AC and DC. The conversation also touches on the use of AC/DC in power supplies and mentions the Australian rock band AC/DC as a cultural reference.
TL;DR: 230 V AC delivers about 85 % of household electricity worldwide [IEA, 2022]; “AC reverses direction, DC doesn’t” [Britannica]. AC means a periodically reversing current, DC means a unidirectional one. Why it matters: Choosing the wrong type can overheat or destroy equipment.
• European mains: 230 V ± 10 %, 50 Hz [IEC 60038]. • US mains: 120 V ± 5 %, 60 Hz [NEC 2020]. • Typical SMPS efficiency: 90–94 % at full load [Energy Star, 2021]. • Safe extra-low voltage (SELV) limit: 50 V AC rms or 120 V DC [IEC 60364-4-41]. • Copper losses rise with frequency squared—doubling frequency quadruples loss [IEEE, 2020].
What exactly is AC?
Alternating current (AC) is an electric current whose instantaneous value periodically reverses sign and follows a repetitive cycle [Britannica] [Elektroda, Freddy, post #18637591]
What exactly is DC?
Direct current (DC) is a unidirectional flow of electric charge—its polarity stays constant even if the voltage level drifts over time [Britannica] [Elektroda, stabilizator, post #18510986]
Does AC have to be sinusoidal?
No. Any waveform that crosses zero and reverses direction—square, triangular, or distorted—qualifies as AC. Power grids use near-sine waves for transformer compatibility [Elektroda, stabilizator, post #18510986]
Can a varying voltage still be called DC?
Yes. If the current never changes direction, engineers still classify it as DC—even when the magnitude fluctuates, as with a discharging battery [Elektroda, stabilizator, post #18512857]
What does an “AC/DC” label on a device mean?
It usually indicates the device accepts both AC and DC input, thanks to an internal rectifier bridge [Elektroda, Anonymous, post #18909158]
Is “variable current” correct English for AC?
No. English uses “alternating current”; German uses “Wechselstrom” for current and “Wechselspannung” for voltage [Elektroda, ken-wawa, #19762003; Elektroda, Adamcyn, #18514328].
Why do modern power supplies convert AC to DC?
Most electronics run on low-voltage DC rails; converting mains AC to DC enables compact, efficient regulation. Over 90 % of electronic devices internally use DC stages [IEEE, 2021].
Can I power a DC device with AC?
Only if the device contains rectification. Supplying 12 V AC to a pure-DC motor will cause vibration and heating, risking failure [Elektroda, Anonymous, post #18909080]
What happens if I connect DC to an AC motor?
An induction motor fed with DC produces no rotating magnetic field; it stalls and overheats within minutes—an edge-case that triggers winding damage [NEMA, 2020].
How do I choose the correct power source?
  1. Read the nameplate for required voltage, current, and AC or DC marking. 2. Match plug polarity for DC outputs. 3. Verify supply delivers ≥ 20 % headroom on current rating. Following these three steps prevents over-voltage or overload faults [Elektroda, stabilizator, post #18512857]
