How do you set up a home automation system using a computer? Ideas and features
diodak1 34761 31
How can I build a computer-based home automation system with sensors, relays, and possible voice control?
A practical setup is a central PC connected to a field network such as RS-485 or 1-Wire, with each sensor or actuator given its own address; relays and other outputs can then be switched through an I/O board or an LPT interface [#281489][#284206][#284501] For temperature measurement, the thread recommends Dallas DS1820/1-Wire sensors; if you use ordinary thermistors, you need a measurement circuit, and the computer can read them via RS232 or USB through a ready-made board or your own design [#283042][#284206][#285412] For the software layer, Delphi was considered suitable, with Delphi 6 or 7 suggested, and LabView or PLC visualisation software was also recommended for larger systems [#284541][#285365][#286984][#287114] A simple LPT driver such as discolitez was also mentioned for controlling up to 32 devices [#318397] Useful functions discussed were heating control, window/blind control, alarms, and remote status monitoring; voice control would need extra speech-recognition software and was judged impractical on weak hardware [#281489][#284501][#318412]
  • #31 318412
    Nemo
    Help: 9
    Rate: 72
    I’m sorry, as someone might take offence.
    I don’t think this sort of excessive automation is a good thing. One day we’ll forget how to breathe, because some ‘convenient’ person will upgrade us to a neural module…
    That’s just my point of view. Computerised heating control – OK. Fridge control – OK (e.g. switching between holiday and normal modes). Voice-activated light switching – sometimes handy. Heater and light in the aquarium – OK. But automatic feeding? I’m not sure it’s a good idea. When we sit down and feed the fish ourselves, we always know exactly how much to put in – what if the fish aren’t actually hungry since the last feeding? Besides, it’s nice to watch them, taking a break from the screen for a moment.
    Personally, I’m a bit sceptical about it. Everyone does as they see fit, though. I wonder how much electricity it’ll actually ‘consume’ and whether it’ll be cost-effective in the end. And just like that, without any exercise, the tummy grows :) then it’s time to lose weight...
    Best regards.
  • #32 325049
    candle
    Monitors specialist
    Help: 38
    Rate: 18
    Finally, diodak1, when setting off on a business trip, will check all the windows on the monitor, set the alarm, leave a note saying when he’ll be away (i.e. when he’ll be back), and when he does return, it turns out that… the window motors are gone, the smoke detectors are gone, the car stereo has vanished, the computer’s gone, and they’ve taken the telly too – basically, you might as well be living on the windowsill – there’s only one thing left: a smoke detector and a window motor that’s broken down :D
    I’m closing this thread; there are too many posts to merge and too many users to warn.
