Solving M980 Monitor Issues: Green Diode, No Image - Chassis Help Needed
dark 2620 6
  • #1 306885
    dark
    Level 19  
    Rate: 14
    This is a 19-inch monitor. There is no image. The diode shines green after a few seconds in yellow. Maybe someone knows what a chasis?
  • #2 306999
    candle
    Monitors specialist
    Help: 38
    Rate: 18
    it may be so from writing that you checked the signal cable and whether the sync pulses reach the prock ...
  • #3 307379
    dark
    Level 19  
    Rate: 14
    I did not check it, but it should probably display that it does not
    comes the signal and the OSD?
  • #4 307384
    candle
    Monitors specialist
    Help: 38
    Rate: 18
    it already depends on the monitor, some pass to the self test, others do not
    do not assume anything and check what is so obvious and negligible ...
  • #5 308954
    dark
    Level 19  
    Rate: 14
    Exactly it is like this: the computer turned off the yellow LED monitor in a moment
    green then again yellow. I turn on the computer again green and it shines all the time, that is, impulses come. With the fact that this monitor has probably two converters and there is no voltage on the bigger one. Very useful for this scheme. I would give the scales, but they are under the screen or are stuck with stickers. The line is probably on the TDA48351i, there are 4 optocouplers on the converters.
  • #6 328187
    dark
    Level 19  
    Rate: 14
    It already works. In this second inverter it was released UC3843. It's still there
    a small glitch in the form of a kind of paler flashing paseczków
    from 4-5 cm from the bottom and top of the screen. The symptom is not steady and more visible
    with clear backgrounds. What can it be?
  • #7 328206
    candle
    Monitors specialist
    Help: 38
    Rate: 18
    check the CRT base and look for cold solder
    listen a little
The discussion revolves around troubleshooting a 19-inch monitor exhibiting no image output, indicated by a green diode that turns yellow after a few seconds. Initial suggestions include checking the signal cable and sync pulses. The author later notes that the monitor's LED behavior suggests signal reception, but there is no voltage on one of the inverters, specifically the UC3843. After some repairs, the monitor functions but displays intermittent pale flashing at the top and bottom of the screen, prompting further inquiries about potential causes, including checking the CRT base for cold solder joints.
