No image from the monitor when the computer is started (no signal from the scree
AksmaitnyGrzmot 23019 18
Why does my PC sometimes start with no monitor signal, and what should I check first?
The fault is most likely in the PC’s startup/graphics path, not the monitor: test the integrated graphics output, remove the GTX 1060, and connect the monitor directly to the motherboard to see whether the machine POSTs at all [#16847690][#16846358] Try another known-good monitor and another cable/adapter, because the signal path or adapter can also be the cause [#16846358][#16846433] Also check whether the CPU and PSU fans spin and whether the system buzzer beeps, since a failed POST or a weak power supply can leave the monitor showing only “no signal” [#16847690][#16846304][#16846221]
  • Intermittent no-signal fixed by reseating GPU cables
    #1 16846205
    AksmaitnyGrzmot
    Hi. As in the subject: recently I have a rather troublesome problem when starting the computer. Namely, sometimes (it happens completely randomly) when the computer is turned on, the monitor does not respond at all (ie only the note about the lack of a signal is displayed). The computer probably turns on normally (without a picture it's hard to tell). At the beginning I disconnected and connected the plugs from the monitor and those from the power strip. It helped, but after each reboot the situation was repeated. Then I opened the computer, cleaned the interior and podociskałem all plugs. After that, the computer and the monitor were running fine for almost two weeks (and the restart did not spoil anything), but today again something did not fit the monitor, because the situation was repeated. Connecting and disconnecting cables from the monitor this time did not help, but re-plugging the pins on the computer again fixed the case (and for now after three reboots everything is ok). Recently also the computer is working really badly, and the mouse / cursor sometimes goes crazy, but I do not know if it has any connection with this launch. I would be very grateful for any information, which may be wrong with my computer. Thanks.
    I do not know if the computer specification will be needed, but in case of:
    Windows 10
    GTX GeForce 1060 6GB
    Intel Core i7-4770 3.40GHz
    16 GB RAM
    Monitor - 2D FHD LG TV-4
    Motherboard - ASROCK H81M-HDS
    Power supply - SSeasonic S12 II Bronze 520W - The power supply and graphics card are very new, because they were bought literally 2 months ago, so probably they are not the problem.
  • #2 16846215
    kiss39
    Help: 397
    Rate: 636
    hmm First check the monitor documentation with the maximum resolution your monitor can work on. Enter the emergency mode of the system key F8 and switch to resolution eg 1024x768 --- Advanced settings >> Monitor >> Screen refresh rate at 60Hz and confirm with OK. restart the PC and the computer should start and you can change the resolution to a higher one such as the Monitor.
  • Suggest testing with a buzzer and removing the GTX 1060
    #3 16846221
    safbot1st
    Help: 2719
    Rate: 1585
    The power supply computer does not have? Give the model and brand.
    Measure with a meter, replace it with another branded one ;)
    In the monitor in its power section you can have dried, cracked capacitors.
    Replacing them will help the monitor to turn on (give the model), but not the start of the motherboard.
    Swap your monitor for another 100% efficient - you'll find out if it's a motherboard. does not start.
    @ kiss39 He does not turn the monitor on completely. Even the windows logo can not be seen (so I understood):
    Not hard at all. Connect the system buzzer and remove the GTX GeForce 1060 6GB.
    Squeaks?
  • #4 16846230
    kokapetyl
    Help: 1787
    Rate: 2101
    It is needed, but also fill in the model plate and the brand / model of the power supply.
    The computer turns on normally
    I do not think so.
    Fill in the missing data, it is also worth to include the screen with HWinfo (sensors-only tab) so that all tabs are visible.
  • #5 16846231
    safbot1st
    Help: 2719
    Rate: 1585
    Next - check the voltage of the CMOS battery. Reset CMOS and restore default settings.
    It's even the hard drive that can block POST or any other component, even the mouse or keyboard.
    Provide SMART with the Crystal Disk Info program.
  • #6 16846239
    kokapetyl
    Help: 1787
    Rate: 2101
    Rather, the monitor turns on, displays the message "no signal"
    I would look for reasons in the PC itself. Unless a damaged signal path in the monitor. :cry:
  • #7 16846304
    safbot1st
    Help: 2719
    Rate: 1585
    Right @kokapetyl
    (ie only the note about no signal is displayed).
    Pretty power-hungry set. I wonder what power supply? It can be a "perpetrator".
  • Safe mode may not help with no signal at boot
    #8 16846311
    AksmaitnyGrzmot
    The monitor can work in a maximum of 1920x1080 (this is recommended). I never switch to any lower or higher. And this emergency mode can work at all with the lack of a monitor signal when the computer is started (in the sense of whether anything appears to me on the screen)? Because, for example, now I am ok, I do not see the point in changing the resolution.
    And so, by the way, I also restored the BIOS to the default settings, because some on the net wrote that it could help, but I did it with these earlier problems, so as today again blew me a monitor, it probably did not help.
  • #9 16846316
    kokapetyl
    Help: 1787
    Rate: 2101
    The question has already been asked, we are awaiting the author's response.
  • Monitor shows no signal, likely PC-side fault
    #10 16846320
    AksmaitnyGrzmot
    I have already updated the specification. The power supply is SSeasonic S12 II Bronze 520W. Practically nówka, because exchanged less than two months ago.
    Added after 5 [minutes]:
    Specifically, I turn on the monitor after turning the power supply on to the back of the computer (before launching the system - LG pops up, no signal, etc.), and after starting the computer it just pops up again "no signal" instead of the mainboard logos and Windows logo, and so it turns on, but the monitor does not respond.
  • #11 16846358
    kokapetyl
    Help: 1787
    Rate: 2101
    it just pops up again "no signal" instead of the motherboard log and Windows logo, and the comp as if it turns on, but the monitor does not respond.
    This is probably a problem that does not turn on properly.
    The problem may be with the graphics card, with connecting it (also with the connection / cable)
    Check another tab / integrated (if any).
  • Adapter or cable likely causing intermittent no-signal
    #12 16846387
    AksmaitnyGrzmot
    It just seems to me that there may be something with the cord. And replacing it with another card, or switching to the one integrated with the prock, probably will not do anything since now the computer can start correctly for up to two weeks (because so much has passed since the last 'failure' with the monitor), so after switching the card and yes I will not know if anything has done it at all.
    The monitor cable also connects to the computer via an adapter - I do not know if it matters.
  • #13 16846433
    kokapetyl
    Help: 1787
    Rate: 2101
    the monitor cable also connects to the computer via an adapter - I do not know if it has any meaning.
    In the previous statement I have already paid attention to the connection, it can also have an impact.
  • Adapter connection may be causing the no-signal issue
    #14 16846915
    AksmaitnyGrzmot
    How can this affect this example? The adapter is also relatively new and I did not have anything to do with it, it is not damaged, etc. I just do not know what the problem may be because I do not recall doing anything with the computer, which could trigger it. Just from day to day the monitor began to fail.
  • #15 16847186
    310artur
    Help: 980
    Rate: 670
    Something "real" there you remember. Why did you replace the power supply and what was it before? The problem was on the old power supply too?
  • #16 16847355
    kiss39
    Help: 397
    Rate: 636
    What is the company of this card?
    Describe the cable connection you used to connect Monitor GTX 1060 graphics card with all adapters and adapters.
  • Old power supply had no monitor issue
    #17 16847409
    AksmaitnyGrzmot
    I do not remember the completely old model of the power supply, and the reason for the replacement was simple - old, would not drag a new graphics card. And on the old power supply there was no such problem, but on the other hand not on the first two months.
  • #18 16847478
    lazania
    Help: 9
    Rate: 20
    "The computer turns on normally." The HDD LED flashes?
  • #19 16847690
    safbot1st
    Help: 2719
    Rate: 1585
    I was supposed to write and I forgot. It is integrated. I advise her to use it @AksmaitnyGrzmot .
    So what if the colleague Velvet can not recognize whether he is turning on the computer or the monitor:
    the monitor began to fail day by day.
    Stand the other monitor and after the topic. Use the "socket" to connect the monitors on the motherboard and the PCI-E card remove . Two birds on one stone, because we will never get there, if you turn on the computer at all.
    The fan in the power supply and on the CPU are spinning ??? P
The discussion revolves around a recurring issue where a computer fails to send a signal to the monitor upon startup, displaying a "no signal" message. The user initially attempted to resolve the problem by reconnecting cables and cleaning the computer's interior, which temporarily fixed the issue. Suggestions from other participants included checking the monitor's maximum resolution, verifying the power supply model (SSeasonic S12 II Bronze 520W), and inspecting for potential hardware failures such as a faulty graphics card (GTX 1060 6GB) or damaged cables. The user confirmed that the monitor works at a maximum resolution of 1920x1080 and had previously reset the BIOS settings. Further troubleshooting steps discussed included testing with a different monitor, checking the CMOS battery voltage, and ensuring proper connections. The intermittent nature of the problem suggests potential issues with the graphics card or power supply.
TL;DR: Reseating connectors restored the display for about 14 days; the intermittent “no signal” returned. “Check another tab/integrated.” [Elektroda, kokapetyl, post #16846358]
Why it matters: This FAQ helps PC users fix random “no signal” on boot by isolating GPU, cable/adapter, PSU, and firmware causes.
Why does my monitor say “No signal” at boot randomly?
Loose GPU seating, flaky cable/adapter, or a failing GPU can interrupt the signal before BIOS appears. Test with integrated graphics to isolate the GPU and link path. This aligns with the advice to check the card, connection, cable, and iGPU first. [Elektroda, kokapetyl, post #16846358]
How do I quickly tell if the GPU or the monitor/cable is at fault?
Connect the monitor to the motherboard video port, remove the PCI‑E GPU, and boot. If video returns, the add‑in GPU or its cable/adapter is suspect. Also try a second, known‑good monitor to rule out the display. [Elektroda, safbot1st, post #16847690]
Can a video adapter or cable really cause a no‑signal on startup?
Yes. Marginal adapters or loose connectors can break the link during initialization. Reseat or replace the adapter and cable, and ensure firm connections at both ends. Connection quality was highlighted as a direct contributor to no‑signal symptoms. [Elektroda, kokapetyl, post #16846433]
How do I use integrated graphics on an ASRock H81M‑HDS to test?
Power down, unplug, and move the display cable from the GPU to the motherboard’s video output. Remove the PCI‑E card for a clean iGPU boot. If it posts with iGPU, focus on the card, its power, or its cable path. [Elektroda, safbot1st, post #16847690]
Should I reset CMOS, and what does it do?
Yes. A CMOS reset restores default firmware settings that might block POST or video init. Pull power, clear CMOS per the board manual, then load defaults. “Reset CMOS and restore default settings.” [Elektroda, safbot1st, post #16846231]
What is POST, and how can the HDD LED help?
POST is the Power‑On Self Test that checks hardware before boot. If the HDD LED never blinks, the system may not reach disk init. A blinking LED suggests it passed some POST stages, narrowing the fault to display path. [Elektroda, lazania, post #16847478]
How can a small speaker (buzzer) help diagnose this?
Attach a system buzzer to the motherboard. Remove the GPU and power on. Beep codes indicate missing GPU or other faults and confirm POST activity without a display. The prompt “Squeaks?” hints at listening for those codes. [Elektroda, safbot1st, post #16846221]
Could the power supply be the reason there’s no image?
Yes. An underperforming or unstable PSU can prevent GPU initialization even if fans spin. Helpers flagged the PSU as a potential culprit on this power‑hungry setup. Swap in a known‑good unit to test. [Elektroda, safbot1st, post #16846304]
It worked for almost two weeks after reseating cables. What does that indicate?
Improvement after reseating points to an intermittent contact issue—connector oxidation, loose PCI‑E seating, or a weak adapter. Stability for about 14 days is a concrete clue that physical connections are central. [Elektroda, AksmaitnyGrzmot, post #16846205]
How do I check disk SMART quickly to rule out storage hangups?
Install CrystalDiskInfo and read SMART status for each drive. A failing disk can stall POST or OS handoff, appearing as a display issue. Capture the report for further diagnostics. [Elektroda, safbot1st, post #16846231]
What resolution and refresh should I try if Windows loads but there’s no picture?
Boot into the F8 troubleshooting mode and set a safe 1024×768 at 60 Hz. Reboot and then raise it to your panel’s native 1920×1080 if stable. This helps if the driver chose an unsupported mode. [Elektroda, kiss39, post #16846215]
Can USB devices really block boot and cause no‑signal symptoms?
Yes. Faulty USB devices, including a mouse or keyboard, can hang POST. Disconnect non‑essentials and retest. This edge case often masquerades as a video failure. [Elektroda, safbot1st, post #16846231]
What is SMART, in simple terms?
SMART stands for Self‑Monitoring, Analysis and Reporting Technology. Drives use it to report health metrics that predict failure. Reviewing SMART helps spot storage problems that stall boot. [Elektroda, safbot1st, post #16846231]
3‑step “No Signal” quick isolation checklist
  1. Move the cable to the motherboard video port and remove the PCI‑E GPU.
  2. Boot with a second, known‑good monitor or cable.
  3. If video returns, focus on the GPU, its power leads, or the adapter path. [Elektroda, safbot1st, post #16847690]
My PSU and GPU are only about 2 months old—does that rule them out?
No. New parts can still be faulty or sensitive to connections. The thread’s PSU and GPU were recent, yet symptoms persisted. Always test with substitutions and reseating, regardless of part age. [Elektroda, AksmaitnyGrzmot, post #16846205]
