Processor Fan Direction: Should it Blow or Draw Air?
p1szcz3k 17847 20
Should a CPU fan blow air onto the heatsink or draw air through it?
The CPU fan should blow air onto the processor heatsink/radiator [#308763][#308764][#311772] Some users note that reversing the fan can be quieter and may still work if the case has good ventilation and the CPU does not overheat [#308849] However, drawing air through the heatsink can pull dust through the fins and send hot air through the fan itself, which may shorten bearing life [#311789][#311867]
  • #1 308751
    p1szcz3k
    Help: 10
    Rate: 25
    I have a question: should the processor fan blow air or draw air into it?
  • #2 308763
    olcha0098
    Help: 22
    Rate: 58
    It is supposed to blow air onto the processor (radiator).
  • #3 308764
    Lukasz
    Help: 73
    Rate: 44
    It should blow on the radiator
  • #4 308790
    stadeks
    of course, blow on the processor, but I turned it on in my PC a long time ago and immediately it became much quieter in the room after turning off the light. If I can write this, it means that the processor is still alive. Regards, Tadek
  • #5 308797
    jozefg
    Help: 197
    Rate: 746
    :arrow: Stadeks
    Can you explain this wonderful phenomenon?[/b]
  • #6 308806
    olcha0098
    Help: 22
    Rate: 58
    And when the light is on, it probably hums like hell :wink: And what's more, you must be terribly cold in the room since your cpu is still alive.
  • #7 308849
    spec
    Help: 21
    Rate: 16
    Gentlemen... no exaggeration! The temperature will, of course, be lower than the fan. blows on the fan, but only when there is good ventilation. and an undemanding process is fan reversal. lowers the number of dB. There is air circulation, and that's what it's all about. It is then taken from outside the radiator, flows through the fins and is also cooled. If the equipment does not overheat, this is a good solution!
  • #8 308856
    jozefg
    Help: 197
    Rate: 746
    stadeks wrote:
    , but I turned it back on my PC a long time ago and suddenly it became much quieter in the room after turning off the light.
    This is what I ment...
  • #9 308905
    robsm
    It became quieter for me when... I got divorced ;-)
  • #10 311772
    babura
    it is supposed to blow on the radiator :)
  • #11 311789
    ACULA
    Help: 105
    Rate: 114
    I will venture to answer that apart from silence there is another plus. Similarly to the power supply, the fan pulls dust from the radiator and does not push it between the fins ;)
  • #12 311794
    Ptolek
    Level 36  
    Help: 318
    Rate: 271
    In my opinion, the difference is negligible, and as for dust, it will be blown in anyway, or rather sucked in (look at the grilles in the computer power supply, dust also settles on the computer side).
  • #13 311867
    sp9ufi
    The only difference is probably that when drawing air from the radiator, hot air passes through the fan itself.
    This may affect its durability. The bearings will probably fail faster. But something for something! Either noise or buy a spare fan.
    Using a computer without a CPU cooler is, in my opinion, inelegant. :)
  • Questioning heat-related fan bearing wear claims
    #14 311913
    spec
    Help: 21
    Rate: 16
    So I've read it three times and I'm wondering what's going on?!
    1) With the processors currently used, there is no question of not cooling the processor (this era ended with the arrival of the 486)
    2) What does the airflow direction have to do with the fan's durability?! Air temperature up to 40*C (because it won't go any higher) and the bearings deteriorate faster?!... I don't think so...
    Could your friend specify/explain what was going on?
  • #15 311927
    sp9ufi
    Hmm!!! I thought I wrote clearly that the fan should blow air onto the radiator. If this is not the case - then try to answer the question: at what temperature is dangerous for the fan... GREETINGS!
  • Fan bearing wear matters more than airflow temperature
    #16 311950
    spec
    Help: 21
    Rate: 16
    Well, it wasn't clear to me from your previous post
    And as for the safest temperature for the fan... well... I think that what is achieved at home has no impact on the operation... Do you really think that it is whether air at a temperature of 25*C flows through the fan? "less destructive" than air at 40*C - for me there is no difference. The bearings in the fans wear out, which leads to their destruction, and the operating temperature (at least within these limits) has no influence on it!!!
  • #17 311958
    Hrabol
    Help: 6
    Rate: 35
    Gentlemen, you are raising a strange problem here, because in my opinion it makes no difference either way, it's just quieter when it blows out and not when it blows in, and now I have a question - should the pump in the toilet first feed the coolant to the coolant or maybe to the cooler and from the cooler to the coolant? ?
  • #18 311960
    sp9ufi
    Exactly! OK - let's finish this topic!
  • Recommends routing coolant through blocks before radiator
    #19 311971
    spec
    Help: 21
    Rate: 16
    When it comes to the toilet, it is better if it flows first into the sink and then into the cooler. The point is that the liquid then gets to the cooling element faster, which is almost important in the case of using additional modules for graphics, chipset or disk. The smaller the distance between the heating element and the radiator, the better!
    And this or vent. whether he inflates into the process or extracts from it, it matters - if you don't believe it... check it yourself! ...besides...if air extraction was as efficient and quieter...why do all manufacturers do it differently? Could they be wrong??... I don't give away the teddy bears... but that's just my opinion :D
  • Radiator-before-processor cooling and exhaust airflow arguments
    #20 312121
    Hrabol
    Help: 6
    Rate: 35
    And I think you're wrong, the circulation is always the same when you have two cooler modules, the flow is always the same regardless of whether the first one is the rotary or the cooler, and besides, it's better to cool it first because then it cools the water and feeds it to the processor, and in in the reverse order, water from the boiler goes to the radiator and goes to the container where there is a pump, and the pump also emits heat
    And this or vent. whether he inflates into the process or extracts from it, it matters - if you don't believe it... check it yourself! ...besides...if air extraction was as efficient and quieter...why do all manufacturers do it differently? Could they be wrong??... I don't give away the teddy bears... but that's just my opinion :D [/quote]
    so why is air extracted from the power supplies???
  • Cooling order matters despite identical liquid flow
    #21 312150
    spec
    Help: 21
    Rate: 16
    And I think you're wrong, the circulation is always the same when you have two cooler modules, the flow is always the same regardless of whether the first one is the rotary or the cooler, and besides, it's better to cool it first because then it cools the water and feeds it to the processor, and in in the reverse order, water from the boiler goes to the radiator and goes to the container where there is a pump, and the pump also emits heat,
    the flow is the same, but the heating elements are different in different places, and it's not about the flow of liquid, it's about dissipating heat as quickly as possible, and the order of connections is important, especially when several blocks are used. (this conversation has gone off topic)
    1) because the power supplies have a different design
    2) because they do not require as good cooling as CPUs
    3) high-class power supplies have 2 fans, one of which pushes air inside
    4) it's about air circulation - the back of the case - the air is pushed out, and the power supply is always at the back
The discussion centers around the optimal direction for a processor fan, with a consensus that the fan should blow air onto the processor or radiator to ensure effective cooling. Several participants noted that this configuration helps maintain lower temperatures and reduces noise levels. Some responses highlighted the importance of good ventilation and air circulation, while others debated the impact of airflow direction on fan durability and dust accumulation. Overall, the majority agreed that blowing air onto the radiator is the preferred method for cooling processors effectively.
