D-Link Router Lease Time Settings, Neostrade 640, Keep Alive Tab & MTU/MRU Configuration
GALILEO 23807 5
  • #1 3396965
    GALILEO
    Help: 10
    Rate: 35
    I have a question in the settings of the d-link router, I have a lease time setting and I don't really know what it is for, I should give it at zero or as much as possible, I have neostrade 640
    I still have the keep alive tab and there I have 10 minutes, that's how much it should be? what is it for?
    well, unfortunate mtu and mru how much is there supposed to be here?
    will you help?
  • #2 3397873
    gothye
    Help: 183
    Rate: 60
    lease time is the default IP lease time by a computer in the network, if a given computer exceeds this time, it sends a request to DHCP for the possibility of extending the lease
  • #3 3399346
    GALILEO
    Help: 10
    Rate: 35
    so how much should i set it to max or minimum?
    gothye
    Help: 183
    Rate: 60
    for 24h - standard, you don't have to worry about its value, it will work with any
  • #5 3412233
    GALILEO
    Help: 10
    Rate: 35
    cool and what are mtu and mru? how much is it supposed to be?
