5V 2.5A Power Supply Wattage Calculation Formula and Example
stasw147 32928 4
  • #1 3444058
    stasw147
    Rate: 43
    Hello, I have such a problem because I have a 5v to 2.5A power supply, what is its power, means how much current it consumes and what is the formula so that you can easily count such things in advance, thank you
    emeryt2
    Help: 717
    Rate: 2302
    Hello, It's very simple :P = UxI, and you don't know the rest, this is a pattern of power.
    ALUŚ
    Level 36  
    Help: 362
    Rate: 20
    Hello !
    P = U x I = 5 x 2.5 = 12.5 W.
    Jerzy Węglorz
    Help: 501
    Rate: 451
    I have a problem because I don't know if you went to school and they usually say something about Ohm's law ...
    Power is the product of voltage and current, so 5V times 2.5A is 12.5W (watts).
    If it is a power supply that takes electricity from the lighting network (230V), the current consumption is 12.5W divided by 230V, which gives 54 mA (milliamperes). Since the efficiency (efficiency, i.e. the ratio of the given power to the power consumed) for such a power supply is approx. 50%, it means that the current consumption will in fact be twice as high (approx. 100mA).
  • #5 3452766
    stasw147
    Rate: 43
    I walked but I had to forget thanks
