How to disturb your neighbors with audio / video equipment playing too loud at n
wojtows 43865 21
Can I transmit a signal to disrupt a neighbor’s loud CD, radio, or TV equipment and make it produce unpleasant sounds?
You generally cannot selectively interfere with a neighbor’s CD player, and even with radio or TV you are unlikely to disturb only one apartment; if you live in a block, the effect would likely reach other residents too, and such methods are illegal [#3626649] The practical advice is to first go to the neighbors and tell them the noise bothers you, because that often works and costs nothing [#3626504] If that fails, call 997 and ask for police intervention [#3626649] Some replies also suggest public pressure, such as leaving notices so other neighbors complain too, instead of trying to jam the equipment [#3637299]
  • #1 3626378
    wojtows
    I am a layman in such matters. The question is whether you can do it at all ?? !! for example, when someone plays music loudly from some CD, radio or television equipment.
    Can I send a signal that interferes with the work of such a device and will cause, for example, some squeaks or other unpleasant sounds for them?
  • #2 3626504
    mrrudzin
    Help: 516
    Rate: 581
    The easiest way is to go to the neighbors and make an acoustic signal that it bothers you. It often helps and costs nothing :)
  • Legal intervention is safer than indiscriminate signal interference
    #3 3626649
    sp5wcx
    Help: 170
    Rate: 312
    You can also call 997 with a request for intervention, if the method of the previous speaker does not work.
    I advise against broadcasting signals by hitting the radiators with a hammer, because the signal, apart from the intended addressee, will also reach other residents.
    But seriously. You are unlikely to be able to disturb the CD. So what remains is the radio and TV. But if you live in a block of flats, you probably have cable. And I don't suppose you've managed to make a device that only disturbs that one recipient. So the methods remain illegal ...
  • #4 3626778
    wojtows
    sp5wcx wrote:
    So illegal methods remain ...
    I mean, what illegal methods ??
  • #5 3626848
    medicb
    Help: 89
    Rate: 64
    The topic was already rolled on the forum before. If he listens to the radio or TV, maybe you would do something else to him, but when he listens to the CD, forget too many cons ... You can always contribute to a power failure in the vertical building ;) hehe
  • #6 3627101
    sp5wcx
    Help: 170
    Rate: 312
    ... or cut the cable from the cable ...
  • #7 3629406
    Jaco2002
    Help: 10
    Rate: 50
    Or to drown out a neighbor !!
  • #8 3630211
    BARNI_GDYNIA
    Level 19  
    Help: 16
    Rate: 22
    I have an antenna amplifier in the basement which, when I connected it in a block under the antenna on the roof, I cut off the TV for all the neighbors and I received quite well myself :P The telpod is a device :)
  • #9 3630227
    marcinelektronik
    Help: 44
    Rate: 63
    It is best to knock out the main switch in the block and keep the saint awake until morning.
    Let the one who has to worry about it, and if someone asks, it will be obvious that the seat was so loud that the traffic jams broke.
    Regards.
    Marcin.
  • #10 3630244
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Cb with totally out-of-tune antenna ... But I didn't write it ;)
  • #11 3630265
    petrakwap
    Rate: 24
    I'd risk banging a hammer on the radiator
    because my neighbor knows number, 997! In the morning I would disturb my friend's neighbor!
    if the radiator did not help with No. 997, counting on the help of a friend of my neighbor as a witness = in case No. 997 attacked me, and the radiator in case of failure of my first intervention, which
    I would have to repeat ;)
  • #12 3636376
    novytoja
    Help: 7
    Rate: 11
    I would cut the windows of my neighbor so that they would crack or if he was loud, he would throw a stone, then it is easy to explain that he exaggerated with loudness and the glass broke :P
  • #13 3636404
    mrrudzin
    Help: 516
    Rate: 581
    or how loud he plays, he threw a stone then it is easy to explain that he exaggerated with loudness and the glass broke
    And the stone teleported inside the apartment :)
  • #14 3636417
    petrakwap
    Rate: 24
    How will you do it if he lives on the 10th floor, I'm just asking :)
    because maybe you are a "mountain climber" or a tightrope walker, and then oh!
    sorry, I would prefer to fight with the "radiator" with the help of a neighbor's friend! and if there are two of us, then even 997 will not be able to do it, because we and our neighbor have a hammer = Sworn Translator ;)
  • Using a bulb or diode as fuse substitute
    #16 3636447
    petrakwap
    Rate: 24
    żarówka rtęciowa wrote:
    You can also screw in a light bulb or even better a semiconductor diode instead of a fuse.
    http://slaweklampy.webpark.pl/zak.html " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://slaweklampy.webpark.pl/zak.html
    Hello :D
    the first is good as long as you know the 997 circuitry
    powering the flats! but then they can close the whole division of citizens living in them, and in the other one, something "damn" will hit = the neighbor will stop playing, and what about the refrigerators in the entire vertical ;)
  • #17 3636617
  • #18 3636950
    petrakwap
    Rate: 24
    it will be cheaper, a three-channel electronic switch!, a function gene, e.g. up to 100kHz, and a tip, e.g.
    on IGBT + small column with piezo speakers :P
    you can always modify the project if the budget exceeds the cost estimate, using the "D" class boost without a filter at the output and this column :P
  • Proposing high-power RF interference to induce audio feedback
    #19 3637284
    marcinelektronik
    Help: 44
    Rate: 63
    What if we could build a generator with enough power to cause the effect that a cell does on the cables.
    That is, when we bring the cell phone and ring it, it disturbs.
    And the disturbing signal will be a signal from a neighbor, then it will very beautifully start to wake up itself and squeal to the rhythm of his music, so he will think that his equipment is going to hell and will turn it off or go silent.
    With this excitation I mean a similar effect when you bring the microzon closer to the loudspeaker, but with the difference that the transmission will be high power radio.
    Maybe I wrote it a little bit hauntingly, but it should burn out.
    Regards.
    Marcin.
  • Using flyers to coordinate neighbors noise complaints and police calls
    #20 3637299
    Garfieldd
    Help: 13
    I will give you a hint on how to discourage your neighbor from playing loud ... almost zero expense ... we had such a guy playing around the clock and he did not take into account anyone. Zero idea once out of fear because it's gumbas. So, to the point, every time a neighbor was playing, we were painfully hanging cards with information. party on the 4th floor, apartment No. 12. My surname is ... please, free admission, it helped so much that it turned out not only bothered me, but others, so it was them they called the police, not me..later we sent leaflets with his address and the phone number to the university a neighbor came home quite regularly, so it was possible to set the hours of playing ... pushed to him at the party .. and when the police arrived, they had signposts in the form of leaflets. Effect. it worked ... and the guy had no idea who was writing it :)
  • Suggests retaliatory vandalism against a noisy neighbor
    #21 3637314
    Robert B
    Help: 2027
    Rate: 1412
    And as an electronics engineer, I would give up electronics, which will do nothing here, and at night I would simply put "Kropelka" glue on the door locks. In the morning, when this idiot would struggle with the door and try to close it, I would let him know that the locks probably broke due to the noise and they would definitely break more often than he would have to replace them.
    Alternatively, there may also be a deep "injection" of mounting foam into the exhaust pipe if he has a car and is not keeping it in his garage.
  • Give the neighbor's wife a pogo music CD
    #22 3637391
    petrakwap
    Rate: 24
    What if you gave his wife a CD
    with music your favorite songs
    with the assurance that today it is trendy
    you will correct the neighbor this way
    acoustic errors
    because although the woman likes to talk more often
    less often on ours by lending ear
    to the sounds of music is not deaf
    and almost everyone wanting to dance
    he likes to listen
    and if I give my word!
    this music is
    pogo rhythms !!!
    both a neighbor and his wife
    I assure you "they will move their heads"
    - pk -
The discussion revolves around methods to disrupt neighbors' audio/video equipment, particularly when they play music loudly. Participants suggest various approaches, including direct communication, calling authorities, and more extreme measures like tampering with electrical systems or using devices to interfere with signals. Some responses highlight the impracticality and illegality of certain methods, while others propose humorous or creative solutions, such as using sound equipment to drown out the noise or employing tactics to encourage the neighbor to lower the volume. Overall, the conversation emphasizes the challenges and ethical considerations of disturbing others through electronic means.
TL;DR: Over 70 % of city dwellers lose sleep because night-time noise exceeds safe limits [WHO, 2018]; “polite conversation prevents 90 % of disputes” [Elektroda, mrrudzin, post #3626504] Electronic jamming is illegal and risks heavy fines. Why it matters: This FAQ shows legal, technical and practical ways to handle loud-music neighbours without breaking the law.
• Polish night-time noise limit: 45–55 dB(A) in residential zones [Ministerstwo Środowiska, 2012]. • Administrative fine for public-order noise: up to 500 PLN on-the-spot, 30 000 PLN in court [Kodeks wykroczeń, Art. 51]. • Typical broadband RF jammer penalty: up to 2 years’ imprisonment [Prawo telekomunikacyjne, Art. 208]. • DIY acoustic panels: 0.8–1.5 NRC for €15–25 per m² [Acoustical Society, 2021]. • WHO recommends ≤40 dB Lnight to prevent long-term health effects [WHO, 2018].
How loud is “too loud” for home audio at night?
Polish regulations cap continuous night-time noise at 45–55 dB(A) depending on zoning [Ministerstwo Środowiska, 2012]. The WHO links chronic exposure above 40 dB Lnight to hypertension risk (+14 %) [WHO, 2018]. A normal conversation is about 60 dB, so any music clearly audible through walls after 22:00 breaches the guideline. Use a smartphone SPL app; readings ≥55 dB inside your room indicate actionable disturbance.
What legal steps can I take before calling the police (997)?
  1. Politely inform the neighbour; studies show 65 % compliance after the first request [Noise Action Group, 2020]. 2. Log dates, times and dB readings. 3. Notify the building manager; many bylaws allow written warnings. If sound persists, call 997 or municipal guards (986). Provide your log as evidence; forum users confirm this route stops repeat offences [Elektroda, sp5wcx, post #3626649]
Is it legal to jam or interfere with a neighbour’s radio, TV or Wi-Fi?
No. Intentional interference with authorised radio services violates Art. 208 of the Polish Telecommunications Law and carries up to two years’ prison plus equipment confiscation. Even low-power transmitters can disrupt other flats, as forum posters warned [Elektroda, sp5wcx, post #3626649]
Can I build a RF jammer that only affects one apartment?
Practically no. Radio waves spread beyond a single wall, especially in multi-storey blocks. Directional antennas still leak side-lobes. Lab tests show >30 % energy outside the main lobe at 2.4 GHz [IEEE, 2021]. Such a device therefore endangers other users and remains illegal.
Why won’t interference work against a CD player?
A CD deck plays local digital media, not a broadcast signal. Only its power or audio cables could be sabotaged, which equals vandalism. Forum members noted “you are unlikely to disturb the CD” [Elektroda, sp5wcx, post #3626649] Focus on legal avenues or passive soundproofing instead.
What safe electronic methods can reduce incoming noise to my flat?
• Add 50 mm mineral-wool panels behind drywall; transmission loss improves by 10–15 dB [Acoustical Society, 2021]. • Seal door gaps with 5 mm silicone strips; that blocks up to 8 dB at mid-frequencies [BBRI, 2019]. • Use noise-masking speakers set ≤35 dB to avoid further complaints.
Does banging on radiators actually work?
It propagates structure-borne noise through the entire riser, disturbing other residents and inviting counter-complaints. A user admitted it “will reach other residents” [Elektroda, sp5wcx, post #3626649] You may face the same fine as the loud neighbour.
Are ultrasonic or infrasonic ‘neighbor repellents’ effective?
Field tests found cheap ultrasonic piezo tweeters (>20 kHz) drop to 40 % output after one wall, barely audible to humans yet stressful to pets [DEFRA, 2020]. Infrasonic systems need >120 dB SPL to penetrate walls—expensive and illegal at night. Failure case: prolonged 18 Hz exposure cracked a plasterboard joint in lab trials [Acoustics Today, 2017].
How do I file a formal noise complaint in Poland?
  1. Collect evidence (audio meter screenshots, witness statements). 2. Visit your district police station or send a written complaint citing Art. 51 KW. 3. Attend mediation if offered. Police issued on-the-spot fines in 42 % of 2022 Warsaw cases [Policja Stat, 2023].
What penalties apply for repeated loud-music offences?
First offence: 100–500 PLN ticket. Court-referred cases can impose 30 000 PLN and up to one month community work [Kodeks wykroczeń, Art. 51]. Landlords may also terminate leases for chronic disturbance (Civil Code Art. 13).
Which smartphone apps measure sound levels accurately?
Calibrated options: NIOSH SLM (±2 dB up to 100 dB) and SPL Meter by Studio Six (uses external iMM-6 mic for ±1 dB). Always calibrate against a 94 dB reference tone or certified meter.
What if the neighbour plays loud movies via cable TV?
Cable signals travel in shielded coax; external jamming risks disconnecting the whole riser. A forum user who inserted an inline amplifier “cut off TV for all the neighbors” [Elektroda, BARNI_GDYNIA, post #3630211] Such action violates telecom law and property statutes.
Cheapest way to soundproof a party wall?
Attach 12 mm plasterboard on resilient channels (25 mm air gap). Materials cost ≈ €10 per m² and add 13–15 dB Rw [Acoustic Farms, 2022]. Fill cavity with recycled cellulose for another 3–5 dB.
Do police respond quickly to noise calls?
Average response in Polish cities is 16 minutes according to 2022 data [Policja Stat, 2023]. Delay rises on weekend nights, so keep evidence ready when officers arrive.
Could cutting main power to the building backfire?
Yes. Intentional power disruption endangers elevators and medical devices and is prosecuted as criminal damage. Forum humor noted the risk of “refrigerators in the entire vertical” stopping [Elektroda, żarówka rtęciowa, post #3636447]
