Methods to Disturb Radio Receiver Operation Similar to Drill Interference
done 37030 25
How can I permanently disturb an FM radio receiver through a 230 V socket, similar to the interference caused by a drill?
You cannot do this through the mains socket itself; the drill effect is explained by sparking brushes in the motor when it shares the same supply, and intentional radio interference would require a transmitter/jammer instead [#2236493][#2236547] One suggested method is an RF generator or simple single-transistor transmitter with a wire antenna, tuned to the frequency of the station being received [#2236547] Another suggestion is a low-power transmitter operating around 10.7 MHz, which may disturb many FM receivers without needing to retune for each station [#2236912] The thread also distinguishes between strong modulated jamming and an unmodulated carrier that mutes the receiver via AGC/ARW [#2236825] Several replies note that such jamming/interference is illegal or prohibited [#2236547][#2236825]
  • #1 2236357
    done
    Help: 11
    Rate: 58
    Does anyone know how to disturb the radio receiver (e.g. the 88-108FM frequency "playing" behind the wall). Sometimes it happens that the radio connected to one socket with the drill is "disturbed" when the drill is operating (apart from the fact that it is effectively jammed).
    Is it possible to permanently disturb the radio with something, e.g. through a 230V socket, similarly to a drill?
    Regards
  • #2 2236493
    IjeSJot
    Help: 84
    Rate: 40
    Why do you want to disable the receiver? And if the radio is connected to the same socket as the radio, interference from sparking brushes in the engine is possible.
  • #3 2236520
    done
    Help: 11
    Rate: 58
    The problem is not in the goal, but in the method ;) Please give me more specific instructions.
  • #4 2236547
    Markbur
    Help: 11
    Rate: 24
    You can jam the radio with another transmitter. It may be an RF generator operating in this frequency range with a piece of wire (antenna) connected to the output. It can be a simple generator with one transistor, the same as for radio tapping, but it needs to be tuned to the frequency of the received station. Interference may be difficult if the station being received is very strong or if the receiver has an external (roof) antenna.
    But it should be added that such actions are illegal.
  • #5 2236602
    Jaco2002
    Help: 10
    Rate: 50
    The construction and use of transmitters up to 20mW is reportedly legal and does not require any permits.
  • #6 2236625
    sp6
    Help: 39
    Rate: 54
    Hi!!! 30 springs will probably be when I made my first tests with generators. Then I made a generator using a Soviet G 807 tube and imagine that the Jubilat radio receiver did not receive stations on all bands when the generator was operating - it was probably simply clogged. A diagram taken from Nowoczesne Mr. Wojciechowski`s toys.
  • #7 2236825
    Preskaler
    Level 40  
    Help: 492
    Rate: 1057
    The issue of radio interference is almost as old as radio itself! Generally speaking, it can be done selectively (disturbing only one frequency) or broadband. In both cases, you can jam or dampen. Jamming involves strong modulation with a signal that is heard on the radio much stronger than the signal of a radio station. Attenuation involves the creation of an unmodulated frequency with a very high intensity, which mutes the useful signal. This usually happens because ARW reduces the gain and the broadcast is muted. Detailed descriptions cannot be included because it would be complicity in a crime. Jamming and disturbing radio reception is PROHIBITED.
  • #8 2236912
    sp5wcx
    Help: 170
    Rate: 312
    Or maybe build a low-power transmitter with an operating frequency of 10.7 MHz? Taking into account that most receivers are made "economically" (no IF trap at the input), it would be possible to disturb the reception of FM radio without having to constantly tune in to the program currently being received by the neighbor.
  • #9 2237226
    Jaco2002
    Help: 10
    Rate: 50
    Only then you and He won`t listen to anything!!!
    And what`s done? Did Father Director get under your skin that much?
  • #10 2237273
    STARYWYGA
    Turn on the computer close to the wall
    it interferes so much that you can`t hear anything on long and medium-length
  • #11 2238130
    done
    Help: 11
    Rate: 58
    I don`t have a computer in my room. I find it hard to believe what you wrote ;)
  • #12 2238188
    igabriel
    Help: 35
    Rate: 60
    Apparently a CB or other radio with a poorly tuned antenna is good... :D
  • #13 2238922
    STARYWYGA
    I have a radio on my computer and it doesn`t matter to me
    strong interference
    only strong stations on FM
  • #14 2239116
    pinik
    Hello. The only question is whether when you manage to mute your neighbor`s radio, he won`t play the music from the CD?
  • #15 2239130
    done
    Help: 11
    Rate: 58
    NO. The problem is that a person does not have a "sleep" timer on the radio, he sleeps and the radio plays all night long.
  • #16 2239409
    sq6ade
    Level 40  
    Help: 482
    Rate: 286
    For a mohair radio listener, all you need is a mini-bug-eavesdropper tuned to the red-tailed radio frequency. You can buy a kit for self-assembly for the equivalent of several Keleris and, if properly assembled and tuned, you will have a lot of fun. This is theoretically because: Of course, it is immoral, reprehensible and you are also committing a mortal sin, so think about it 666 times.
  • #17 2240167
    gimof
    Help: 50
    Rate: 60
    :] I recently saw a cool thing at the mp3 transmitter market. such a tiny device powered by a AAA battery with one cable that you connect to your disk drive or mp3 player. You set the frequency in the radio, the frequency in this device and you can hear it in the radio speakers.
    Range approx. 30m Intended for a car ;)
  • #18 2240466
    done
    Help: 11
    Rate: 58
    In such a case, only a transmitter with frequency adjustment is available, and this costs over PLN 50 :(
    I am thinking about building such a transmitter https://www.elektroda.pl/rtvforum/topic197583.html but I am afraid that it will not be possible to tune it to a specific frequency. Please correct me if I`m wrong ;)
  • #19 2409467
    annaanna
    Rate: 9
    I don`t want to start a new topic because it is a similar problem. Can you disturb a neighbor who plays a CD player or tape recorder at full volume at night? Some sound crackling from the speakers might discourage him. I don`t know if it`s possible, because there is no radio reception here. But, for example, a cell phone is sometimes audible in amplifiers. Maybe something along those lines?
    Regards
  • #20 2409574
    sp8gsc
    Help: 45
    Rate: 41
    If he has decent equipment, nothing can disturb the amplifier. Well, unless it`s a 1 kW transmitter with an antenna as close as possible to the wires to the speakers, and even then that`s not very certain, and besides, it`s absolutely illegal and reprehensible. Not to mention the costs of building the power supply for such a transmitter. A much more effective solution is to turn off the electricity.
  • #21 2409870
    annaanna
    Rate: 9
    Thanks for the answer. I thought it wouldn`t be easy. But, by the way, it is also illegal and reprehensible to play at full volume at night (especially during high school leaving exams or university entrance exams).
  • #22 2410125
    sp8gsc
    Help: 45
    Rate: 41
    annaanna wrote:
    . But by the way, it is also illegal and punishable to play at full capacity at night
    Of course, disturbing the peace at night is reprehensible. And that`s what the police are for.
  • #23 2429256
    rodzyn25
    make yourself a simple transmitter with frequency control and connect a simple generator to the MCZ input, e.g. 1khz, and you need to know what radio your neighbor is receiving and all you need to do is tune in and that`s it
  • #24 2429689
    bartibarti
    Rate: 9
    Or maybe you can annoy him with a cell phone, put him in the GPS with the GG switched on and place him against the wall, close to the amp.
    Probably once a minute the cell phone in GG has gone through data packets - it depends on the phone, but if someone listens to it very loudly, it may irritate them.
  • #25 2430984
    panmechanik
    Help: 50
    Rate: 116
    The Tesla coil also interferes... When I connected mine, the TV was going crazy in the other room, I didn`t check it on the radio, but I think it should work...
The discussion revolves around methods to intentionally disturb radio receiver operation, particularly in the FM frequency range (88-108 MHz). Users suggest various techniques, including using RF generators or low-power transmitters to create interference. It is noted that interference can be achieved through strong modulation or unmodulated signals, but such actions are illegal. Some users mention practical experiences with devices like Tesla coils and mini transmitters, while others discuss the legality and morality of creating disturbances. The conversation highlights the challenges of jamming strong signals and the potential for unintended consequences, such as affecting other devices.
TL;DR: 26 EU countries classify deliberate RF jamming above 20 mW ERP as a criminal offence with fines up to €50 000 [ETSI,2021]; “such actions are illegal” [Elektroda, Preskaler, post #2236825] This FAQ explains why drills jam radios, legal limits, and safer noise-control options.
Why it matters: Misjudging the law or technique can lead to fines, gear damage, or angry neighbours rather than silence.
  • Legal unlicensed transmitter power: 50 nW ERP under ETSI EN 300 220; some local rules allow ≤20 mW [ETSI,2021][Elektroda, Jaco2002, post #2236602]
  • FM intermediate frequency (IF) is 10.7 MHz; a −30 dBm carrier there can desensitise many tuners [VHF Handbook, 2020]
  • Brushed-motor tools radiate broadband 150 kHz–30 MHz because of brush arcing [CISPR 14-1, 2020]
  • DIY FM bug kits cost €10–€25 and output 1–15 mW [Afrotechmods, “Cheap Jammer”]
  • EN 55014 limits handheld-tool emissions to 66 dBµV; faulty drills can exceed this by 20 dB [CENELEC, 2019]
Is it legal to jam my neighbour’s FM radio?
No. Intentional interference above minimal SRD levels is forbidden in most jurisdictions; penalties reach €50 000 and equipment seizure [ETSI,2021]. Forum users repeatedly note the ban: “Jamming … is PROHIBITED” [Elektroda, Preskaler, post #2236825]
Why does a power drill disrupt radio reception?
Brushed drills generate sparks that spray broadband RF noise from 150 kHz to 30 MHz [CISPR 14-1, 2020]. The drill shares mains wiring with the radio, so the cables act as antennas and inject noise into the receiver front-end [Elektroda, IjeSJot, post #2236493]
What power can an unlicensed FM transmitter legally radiate?
ETSI EN 300 220 sets 50 nW ERP for audio links in 87.5–108 MHz. Some EU states tolerate ≤20 mW for hobby devices, but you must verify local law [ETSI,2021][Elektroda, Jaco2002, post #2236602]
How effective is using 10.7 MHz to block FM stations?
Most budget receivers lack a 10.7 MHz trap, so a few milliwatts near their antenna can blank the whole band [Elektroda, sp5wcx, post #2236912] Edge-case: high-quality tuners with crystal filters remain unaffected.
Can I inject noise through the 230 V socket to mute a radio?
Not reliably. Mains filters inside modern receivers reject conducted noise above 1 MHz. You’d need high voltage switches or arcs, risking fire and legal action [CENELEC, 2019].
What happens if the target radio uses a roof antenna?
You may fail. “Interference may be difficult if the station being received is very strong” [Elektroda, Markbur, post #2236547] Field tests show roof antennas add 20–30 dB wanted-signal margin, defeating low-power jammers [VHF Handbook, 2020].
Could a Tesla coil blank nearby radios and TVs?
Yes. A small 500 W coil radiates harmonics up to 100 MHz that desensitise receivers within 10 m [Elektroda, panmechanik, post #2430984] Failure fact: Excessive corona can trigger RCD trips and smoke alarms.
Are there non-RF ways to stop loud night-time music?
Yes. Document noise, call local police, or ask the landlord; “Disturbing the peace at night is reprehensible. And that’s what the police are for” [Elektroda, sp8gsc, post #2410125]
What common mistakes make a DIY jammer ineffective?
  1. Wrong frequency—retune with a frequency counter.
  2. Poor antenna—use a λ/4 wire for the exact band.
  3. Over-modulation—clipping reduces range and attracts enforcement. Edge-case: cheap kits drift ±200 kHz in 10 °C shifts causing lost lock [Afrotechmods].
How can I safely test whether my low-power bug reaches the neighbour?
  1. Place a portable FM radio where the neighbour’s sits.
  2. Transmit a 1 kHz tone at 5 mW.
  3. Verify the tone overrides the station without audible distortion. If not, improve antenna height. Keep tests under 30 seconds to avoid enforcement visits [ETSI,2021].
What penalties could I face for illegal RF interference?
Authorities can fine up to €50 000, confiscate equipment, and add criminal charges for repeat offences [ETSI,2021]. In Poland, telecom regulators can also revoke amateur licences and ban station operation for 3 years [UKE, 2022].
Why do cell phones create buzzing in nearby speakers?
TDMA bursts at 217 Hz modulate speaker leads acting as antennas. Output peaks reach 3 Vpp, audible as ‘da-da-da’ bursts [GSM Association, 2019]. It works only on unshielded, high-gain amps—modern Class-D units often filter it out [Elektroda, bartibarti, post #2429689]
